Author: Subject: Anti Roll Bars
lsdweb
posted on 29/1/09 at 08:27 AM Reply With Quote
Anti Roll Bars
Hi All
Anybody on here selling anti rollbars for a 7esque car?
Ta
Wyn
Mr Whippy
posted on 29/1/09 at 08:42 AM Reply With Quote
you can just take one off a production car and use link arms to connect it to the bottom wishbones, small fiat should be close. See how they have mounted and connected this bar in the pic, very easy to do and can use any bar that will fit in between the wishbones. To stop it sliding side ways simply fit some clamps either side of the bar chassis mountings, something like these ones.
smart51
posted on 29/1/09 at 08:58 AM Reply With Quote
catherham sell a nice range of ARB sutiable for a seven. They do diffent stiffnesses and widths and their prices are quite reasonable.
procomp
posted on 29/1/09 at 09:51 AM Reply With Quote
Hi
Mr Whippy you realy do talk rubbish sometimes.
Cheers Matt
Mr Whippy
posted on 29/1/09 at 10:26 AM Reply With Quote
Originally posted by procomp
Hi
Cheers Matt
explain?
procomp
posted on 29/1/09 at 10:34 AM Reply With Quote
Hi
Anti roll bars are used as a device for fine tuning the cars weight transfers. And you have just suggested that any bar of a tin top that will fit in between the wishbones will do.
You do not seem to understand just how much effort goes into selecting roll bar dimensions to get them to work on such a light car or what effect very small changes to those dimensions has.
Cheers Matt
Cheers Matt
Mr Whippy
posted on 29/1/09 at 10:49 AM Reply With Quote
Hi
Cheers Matt
Hi
Cheers Matt
Cheers Matt
Perhaps but he never said he wanted to race only if there were bars available. I simply suggested a method of obtaining a bar and how it could be fitted. I also provided a picture of how a similar bar had been fitted to a Lotus, plus if you look at the picture you’ll see that the link is adjustable so that the spring rate can be adjusted, so getting the rating ‘just right’ when you don’t actually know what that might be exactly for your car isn’t as important.
This is a Locost forum and home built is what this site is all about, not go to a shop and buy one off the shelf, otherwise this would be the something like the Westfield Forum. It’s easy to criticize others suggestions, far harder to some it seems to actually contribute. We have never had a policy of censoring of discouraged members to offer suggestions (though I have seen some who have tried this in the past) and that’s how many of us have learned something new.
Certainly openly criticizing members on here is normally considered plain rude. Though I have a thick skin being an ex-bus driver
[Edited on 29/1/09 by Mr Whippy]
posted on 29/1/09 at 10:59 AM Reply With Quote
If the production ARB is too strong thin it down with the angle grinder, it works on pen knife back springs 'cos I've tried it. Carry on Whippy
carpmart
Easy boys!
Its a simple case of good intentions to help from Mr Wippy, though maybe a little simplistic with the advise and Matt pointing out that a lot more 'precision' needs to go into the selection of the right arb!
So, lots of love all round then!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
johnston
posted on 29/1/09 at 11:21 AM Reply With Quote
There is a formula to work out the rating of a roll bar, going on size length bends etc etc..
A mate of mine uses it to make them for different rally cars.
Find out what you need/want go measure a few tin top's and remember you can lengthen or shorten the arms to suit.
Some of the higher spec mk2 fiestas had quite soft ones at the back.
marmot0
posted on 29/1/09 at 11:40 AM Reply With Quote
formula:
Q = 10x10x10x10 xTxTxdxdxdxd
_______________________
RxRxL
Where
T=track
K= fractional lever arm ratio
d= bar diameter
R reflective arm length
L= half length of bar
S= Length of leaver arm
Q = stiffness in LB
