Author: Subject: iva
heyzee
posted on 1/2/09 at 09:42 AM Reply With Quote
iva
just read a thread on the iva test,just in the process of starting my build again after about a 3 year gap.(bad move by the look of it)i am useing a 2004 r1 fuel injection motor,radiator ex-up valve and clocks.now i have read that you will need a reverse gear box,do you think it is worth while continuing with the bike engine.or will it prove to costly,and is now a good time to swap?????
cd.thomson
posted on 1/2/09 at 09:46 AM Reply With Quote
As far as I am aware the problems with bike engines and IVA are that a reverse gear is now compulsory and the ever present noise issue which can be solved with a carefully put together exhaust system.
I say go for it as changing over to a car engine will probably cost you just as much, if not more anyway!
I'm building a CEC btw, so my statement has no BEC builder bias
Craig
nitram38
posted on 1/2/09 at 09:47 AM Reply With Quote
Talk to Russ Bost about a reverse setup.
His one isn't too expensive.
heyzee
posted on 1/2/09 at 09:54 AM Reply With Quote
how mutch is not too expensive ??? good job i never got a prop made up otherwise that would have been money down the swanny
marmot0
posted on 1/2/09 at 09:57 AM Reply With Quote
Don't forget noise test is now 98dB, i am having trouble getting 101 dB
nitram38
posted on 1/2/09 at 09:58 AM Reply With Quote
Well mine cost £360 from lynxae but Russ's one is at least half that.
The main thing is to get the sprocket and you can source a starter to suit. I think he uses an MR2 one.
nitram38
posted on 1/2/09 at 10:02 AM Reply With Quote
I am using a cat from the US (martin keenan sells them too) and a Quill Carbon can.
I have a noise meter ready, but I have not run the engine yet.
I am looking for an exhaust guard.
If it is too loud I plan on getting one of those inserts from cbsonline and shoving it in the tail pipe for sva.
[Edited on 1/2/2009 by nitram38]
marmot0
posted on 1/2/09 at 11:48 AM Reply With Quote
I failed my first SVA due to noise, have just put an airbox on which has won me back around 10dB the induction roar was huge, I have also lagged the bonnet with accoustic foam
nitram38
posted on 1/2/09 at 12:20 PM Reply With Quote
Luckily, I will be fitting the original airbox as there are no space limits on my engine.
heyzee
posted on 1/2/09 at 01:14 PM Reply With Quote
what sprocket and where does it go any pictures
nitram38
posted on 1/2/09 at 01:18 PM Reply With Quote
I'll say it again CONTACT RUSS BOST!
Dangle_kt
posted on 1/2/09 at 03:07 PM Reply With Quote
nitram, whats the specs on that reverse?
