Author: Subject: Mirrors - SVA ok?
chrisg
posted on 2/2/09 at 01:17 PM Reply With Quote
Mirrors - SVA ok?
Do you think these mirrors would be ok for the SVA?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 2/2/09 at 01:28 PM Reply With Quote
Can't see why not. SVA man might ask for the exposedhex section to be covered (very picky IMHO), bu that shuld be easy enough with a bit of tape or a modified nut cover.
chrisg
posted on 2/2/09 at 01:34 PM Reply With Quote
Actually I saw a very neat solution to that the other day the stem was covered in a thin foam rubber and then the whole thing was covered in heat shrink - looked pretty good.
Thanks Nick!
Chris
Mr Whippy
posted on 2/2/09 at 01:48 PM Reply With Quote
same mirrors as my CBR125 & CG125 came with, since chucked them and put on some nicer ones
neilj37
posted on 2/2/09 at 02:24 PM Reply With Quote
I would fit some heat shrink over it prior to installation and then just shrink it when fitted to cover the hex nut. Tidy and simple
James
posted on 2/2/09 at 04:10 PM Reply With Quote
If the glass is big enough for the regs and the edge radius is ok then don't see why not.
My only issue mght be that when fitting them to the curve of the scuttle, are they going to end up at a funny angle?
James
Avoneer
posted on 2/2/09 at 07:21 PM Reply With Quote
Don't bother with the heatshrink and all that balls.
Take the hex bit off.
Drill a hole the same diameter of the threaded section in your scuttle (or wherever).
Insert a large washers onto the threaded bit.
Insert through drilled hole on car.
Use the hex bit on the inside.
Numpties.
Pat...
chrisg
posted on 2/2/09 at 07:55 PM Reply With Quote
Numpties.
Pat...
Pat - the voice of reason!!
How you doing mate?
Chris
Krismc
posted on 2/2/09 at 09:38 PM Reply With Quote
Where they from?? im still looking for a set!!
chrisg
posted on 3/2/09 at 12:35 PM Reply With Quote
Mirrors on the bay
Chris
Avoneer
posted on 11/2/09 at 07:50 PM Reply With Quote
I'm still around, but enjoying my MX5 (soon to be Megasquirted and turbo'd).
Best thing is that it's currently about 2 secs a lap quicker than the Bitsablade was at Donington.
http://www.youtube.com/watch?v=BDcMa9lpe88&feature=channel_page
Pat...
