MrFozzieBear
posted on 2/2/09 at 06:17 PM |
Pricing on Zetec
Its been a while since i was on here last,
I've been offered a 2 litre silver top Zetec which is my engine of choice for my project, with loom and ecu although ecu will be surplus to
requirements if I go ahead with my plan and loom for reference.
Just wondering if anyone could help on how much you reckon its worth I’ve been assured it was running well before removal. Although i will be striping
the lot for rebuild. However mileage is unknown.
If any one could help with pricing for the lot and just the engine on its own it would be a great help to me.
Thanks,
mongrelwestie
posted on 2/2/09 at 06:22 PM |
you can get the engones on there own for about 85-150 from most breakers
posted on 2/2/09 at 06:38 PM |
By the time you have brought the engine and rebuilt it you may find it costs more than a new engine? Zetec don't seem to suffer engine wear too
badly if they have been run on the correct oil .May be better to get an engine you can see running before parting with any hard earned?
big_wasa
posted on 2/2/09 at 06:49 PM |
A good 2L is worth upto £200. Maybe a touch more for a very good Pre aug 95 motor.
You would be looking at a big bill to rebuild one. I spent a fortune on mine but it didnt really need it.
Best value is to clean it, thrash it and kill it, then buy another
[Edited on 2/2/09 by big_wasa]
focijohn
posted on 2/2/09 at 06:50 PM |
Mine cost me £50 1996 was told it was good runner.... with everything attached to the engine. About £100 for mains and big ends, £25ish quid for con
rod bolts. Been quoted for the following parts(IIRC): Head set and bolts about £100 (but not looked around) and about £50 for bottom end gasket set
(not shopped around yet). Water pump 1800 escort £30. And oil pump i am undecided but i know that a mate at ford bought one for a 1800 escort and this
cost him £80. And the cambelt on my focus was £70 so this is what i am assuming it will be...
HTH
John
[Edited on 2/2/09 by focijohn]
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
posted on 2/2/09 at 07:01 PM |
New Black Top engine including manifolds ,injectors etc £700 from Robon Hoods new owners . Might be worth checking the price from Fords?
zetec
posted on 2/2/09 at 08:29 PM |
As said dont pay too much, the bottom ends are reliable. If you decide do anything have the head off and do some porting and lap the valves in with
some new stem seals. Costs very little to do and you can always re use the head if you manage to break the bottom end. The only real mileage related
issue I've found is pitted valves. Also to bear in mind they are a bit of a pain to get out of a Mondeo as you tend to have to drop it along
with the front sub frame...lots of hassle to get it out through the bonnet...I know!![](/images//smilies/mad.gif)
MrFozzieBear
posted on 2/2/09 at 08:47 PM |
Thats excellent thanks for your help.
Im going for a pre-aug95 zetec silvertop. and rebuilds so i can change and check everything to supercharge it. changing compression ratio the proper
way and not with a plate. and changing all the internals. its not going to be cheap i know that but luckly i have a friend in the trade in sourcing
the internals for me.
austin man
posted on 2/2/09 at 09:02 PM |
nephew has just had his reconed up for use with a turbo I think the cost is running at £1500 and upwards including correct turbo pistons, no head
work and no management system included
