Author: Subject: Mk2 Golf indicator failure
James
posted on 9/2/09 at 12:47 PM Reply With Quote
All of the indicators have failed on my MK2 Golf.
Obviously a fuse or the relay is first thought but:
Bit of an odd one though, because they all still work if I press the Hazard button.
For some reason the indicator 'tell-tale' LED is on dimly all the time (with ignition on).
If I press the indicator lever then the LED 'tell-tale' flashes brighter at the correct speed and brightness.
Am I being silly and missing something obvious?
I would assume the indicator lever had gone but for the fact it operates the 'tell-tale' LED correctly.
Can anyone advise? I'm scared to drive it and get pulled by the Police... or cause an accident for that matter!
James
posted on 9/2/09 at 01:00 PM Reply With Quote
Maybe a partial short somewhere?
With hazards on, do all 6 bulbs work correctly - have seen odd behaviour before when a bulb has blown.
As said, check fuse(s) and relay first, then column switch.
Mr Whippy
James
thats a laugh the police never use their indicators
posted on 9/2/09 at 01:47 PM Reply With Quote
Is there a seperate indicator relay? Some cars have a seperate one for indicator and hazards...
posted on 9/2/09 at 02:04 PM Reply With Quote
I would suspect the flasher relay has gone to VW heaven- that is where I'd look first. I though most cars had there are 2 separate units?
k33ts
posted on 9/2/09 at 03:57 PM Reply With Quote
could be the hazard switch itself or just down to a bad earth.
tukcustoms.com
James
posted on 9/2/09 at 06:48 PM Reply With Quote
Thanks for the advice every one.
Hmmm, well I've been a bit pathetic in this weather and not really done much other than found that one of the indicators has gone.
And when I say gone, I mean actually gone, the front bulb holder and loom up to the connector have disappeared leaving just the loom!
So maybe damp has got into the connector and is causing a short?
Bugger!
Lets hope it's dry tomorrow. Anyone got a MK2 Golf, big bumper, RHS indicator bulb holder?
James
[Edited on 9/2/09 by James]
hillbillyracer
posted on 10/2/09 at 11:12 PM Reply With Quote
I've got one of the said bulb indicator holder but I'm afriad it's staying attached to my mk2 big bumper Golf!
The indicators on it did a strange thing for a while, I pulled up at a cash machine & had the sidelights on & just stopped it & pulled the key out with the indicator still flashing & the car kept running! I assumed it was feeding the ignition circuit from the sidelights through the indicators (on a VW the side lights & indicators are linked so you can leave one side light on while parked) but thought it cant be right. A few weeks later the ignition switch failed (a common fault) & with a new switch fitted the running with no keys thing stopped.
posted on 11/2/09 at 09:11 AM Reply With Quote
Well in that case, what you said earlier is not true:
James
posted on 13/2/09 at 06:31 PM Reply With Quote
Problem fixed...
extremely complex and difficult fix...
fuse had blown!
Weather some water had got into the connector where it was missing and blown the fuse I don't know. So maybe it'll go again... but with the new fuse and the bulb holder replaced it's all good.
Thanks for the advice people.
James
