Author: Subject: From this .....To this.....
big_wasa
posted on 22/2/09 at 03:04 PM Reply With Quote
Just wanted to share this with you lot.
From this
Image deleted by owner
To this
And the best bit, this.
I didnt think my lathe would do it but it has just about
They are gsxr 750 Tb to Dcoe manifold adapters.
The centers are tappered and still need to be hand ported and polished up.
I really want a mill as I hate cutting and sanding the sides
Just the other three to go when I get some time.......................
blakep82
posted on 22/2/09 at 03:06 PM Reply With Quote
oooh lovely
________________________
tomgregory2000
posted on 22/2/09 at 03:07 PM Reply With Quote
good effort that man
i like
mangogrooveworkshop
posted on 22/2/09 at 03:08 PM Reply With Quote
Thats very nice.......loads of swarf
Keep up the good work
speedyxjs
posted on 22/2/09 at 03:12 PM Reply With Quote
Very nice
Gotta get me one of them lathes
YQUSTA
posted on 22/2/09 at 03:23 PM Reply With Quote
very nice work looks well
posted on 22/2/09 at 03:44 PM Reply With Quote
Wow! I'm so jealous of people with lathes!!!
omega0684
posted on 22/2/09 at 04:08 PM Reply With Quote
a very nice result warren, but how much was that big chunk of ali? seems to be a lot of wastage there?
flak monkey
Nice
You managed to get some material then?
Sera
http://www.motosera.com
Steve Hignett
posted on 22/2/09 at 05:08 PM Reply With Quote
Why bother with all that work???
why didn't you just use
this one?
[Edited on 22/2/09 by Steve Hignett]
maskedavenger
posted on 22/2/09 at 05:09 PM Reply With Quote
very nice how long did it take you iff youve still got 3 to do why is there one in the top pic
Miks15
posted on 22/2/09 at 05:17 PM Reply With Quote
i assume he didnt think to take a pic of the block of ally before machining the part so took a pic of both bits after, with the block being a bit for one of the other ones to be made
minitici
posted on 22/2/09 at 05:33 PM Reply With Quote
Very nice - but did you consider welding a bit of thick walled tube to a flange?
jlparsons
posted on 22/2/09 at 06:01 PM Reply With Quote
Looks sweet mate, I wish I had enough patience but I know if I'd made it, it would function but not look anyway near as nice.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
Simon
posted on 22/2/09 at 07:03 PM Reply With Quote
I agree
But, nice anyway!
Simon
big_wasa
posted on 22/2/09 at 07:09 PM Reply With Quote
Spot on Miks.
I had thought about a steel tube welded to a flange but its not very neat. And my lathe doesnt like steal over about an inch dia.
The four bits of alloy came up on yes you have guesed it, ebay . Cheap as they all had a hole through them
My lathe is tiny so I can only take small cuts. So its taken about eight hours to do that one to that stage.
I am pleased with the results but wouldnt want to go into production
g.gilo
posted on 22/2/09 at 07:29 PM Reply With Quote
mill
hi there
bolt the turned part down to cross slide at centre height, end mill in lathe chuck, mill sides of flange in minutes.
regards graham
retired boring? old toolmaker.
