locoboy
posted on 25/2/09 at 08:23 PM |
purely out of interest
Are there any diesel engines out there that will mate up to commnly used RWD gearboxes as used in 7 style cars.
Engines such as the 2.0 hdi from the pug 306 etc, these are relatively cheap and torquey with 100+ bhp and can be remapped easily.
Just curious.
Locoboy
flak monkey
posted on 25/2/09 at 08:25 PM |
A duratorq ought to mount to a t9 with a duratec bellhousing fitted...torque might not do it any good though!
Sera
http://www.motosera.com
stevebubs
posted on 25/2/09 at 08:36 PM |
Transit motah!
stevebubs
posted on 25/2/09 at 08:37 PM |
If you're lucky, you may find a manual Omega diesel...comes complete with RWD box...
stevebubs
oh..and it's a BMW unit so you may be able to swap for something a bit bigger...
flak monkey
posted on 25/2/09 at 08:43 PM |
Actually thats a point, the transit 6 speed which is fitted to the diesels and petrols will bolt straight to a duratec too... first is useless
though!
Sera
johnston
posted on 25/2/09 at 09:03 PM |
I was wondering if the 2.5td pug engine in ldv's has the same bolt pattern as the the smaller diesel pugs or hdi engines. because some ldvs run
a ford box with a adapter plate to go on the pug engine..
In theory Hdi or xud, adapter plate then ford box.
Get the right engine/inj pump and go veggie oil
dinosaurjuice
posted on 25/2/09 at 11:12 PM |
the ford TDCi/PSA HDi have same bolt pattern as zetec as they share gearboxes. BUT there are not many rwd boxes that will take the torque.
the newer MT75 used in the transit (6 speed) seems obvious choice but apparently there incredibly unreliable... the older version (1994?-2000?) may be
OK.
best to go mid engine and use the standard gearbox IMO.
Simon
posted on 25/2/09 at 11:39 PM |
Jag Turbo diesels 2.0, 2.2 (4 cyls), 2.7 V6 are rwd (and this also goes in fwd peugeot/citroen too), then there's BMW tdi's incl the
200+bhp 123(?)d.
However, Jag have just launched the XF 3l diesel s which gets the XF to 60 in under 6 secs (and 42ish mpg), but I doubt you'll find a breaker
any time soon
Simon
[Edited on 25/2/09 by Simon]
g.gilo
posted on 26/2/09 at 09:28 AM |
daga
is the ldv engine not the old granada/siera motor, used a ford box in those days;
alistairolsen
posted on 26/2/09 at 10:42 AM |
I think the vauxhall 1.3, 1.7 and 1.9 cdti engines all use the std GM flange and therefore the omega box would fit.
A v6 omega has 200ftlbs torque so the 150bhp 1.9 tdi should be fine.
Would make a cool car!
DarrenW
posted on 26/2/09 at 05:55 PM |
200+bhp 123(?)d.
any time soon
Simon
I dont think id insult a 7 by fitting BMW tdi at the mo - but maybe im bitter!
Simon
posted on 26/2/09 at 09:09 PM |
I wasn't going to mention it, but someone on here (who's name has escaped me) has one, so I thought I'd mention it in case he
did.
When you say "bitter", are you, or are you learning german
danke
Simon
ss1turbo
posted on 26/2/09 at 10:38 PM |
There is an XUD/HDI solution - the LDV Pilot (original 200 Sherpa) used an XUD with a Rover R380 box.
The Convoy/Sherpa 300 had a right collection of engines over the years - L series/Perkins (so anything which fitted an O series - LT77, I think), Pug
(not sure) and the Trannie 2.5/MT75 combo.
Only issue with van boxes is they tend to have wierd gear linkages which would probably put the lever level through the scuttle...
Long live RWD...
