<<  1    2  >>
Author: Subject: Nice start button?
posted on 5/3/09 at 08:49 PM Reply With Quote
Nice start button?
I'm planning to re-wire my ignition switch in the very near future. At the moment, if the engine doesn't start I have to turn the ignition off and on again. This is fine, but it means that I have to re-activate the immobiliser (home brew thing, so it's entirely my fault!). A separate button would fix that problem.
So, I'm looking for a smart button, preferably with 'START' on the front. It'll need to carry the current for a crossflow solenoid. Any ideas?
I've seen those Honda ones, but they go for stupid money on ebay so I'm looking for an alternative!
McLannahan
posted on 5/3/09 at 08:52 PM Reply With Quote
Savage?
or the larger one?
[Edited on 5/3/09 by McLannahan]
maskedavenger
posted on 5/3/09 at 08:54 PM Reply With Quote
car builders solutions do them for about a 10ner
mr henderson
posted on 5/3/09 at 09:11 PM Reply With Quote
The Savage ones look pretty good, but I would be happier using a relay in the circuit. Easy enough to do, and pretty cheap too.
John
nitram38
posted on 5/3/09 at 09:18 PM Reply With Quote
Savage good for switching 10A so as long as your solenoid trigger is less (which it most likely is) it will not need a relay.
posted on 5/3/09 at 10:06 PM Reply With Quote
I use a Maplins anti-vandal one for about a fiver. Works fine....
posted on 5/3/09 at 10:16 PM Reply With Quote
Actually, that does look ideal... illuminated, too! £7.50 + P&P + VAT.
contaminated
posted on 5/3/09 at 10:25 PM Reply With Quote
I use the above CBS one. For the money the quality is really good. I wired the internal light up as an ignition light - so it comes on when it needs pressing and goes out when the car has started.
Another alternative. Very good quality.
Phil
jlparsons
posted on 5/3/09 at 10:33 PM Reply With Quote
i like the car builder solutions one. It would take just a little electric mayhem like this:
to make it pulse like a jag XF start switch too. I was thinking pulsing before engine start and permanently on when engine running? Yes, a bit theatrical, but cool as hell.
paulf
posted on 5/3/09 at 10:35 PM Reply With Quote
That looks like a telemechanique industrial switch with engine start printed on the button.We use lots of them at work but I hadnt thought of that use for one.
Paul
posted on 5/3/09 at 11:08 PM Reply With Quote
I believe the CBS switches are the same as the Maplin anti-vandal ones just marked up 100%
a4gom
posted on 6/3/09 at 12:02 AM Reply With Quote
do you have a maplin linky or part no?
Perfect planning prevents pi$$ poor performance!
scudderfish
posted on 6/3/09 at 07:18 AM Reply With Quote
Click for Maplins switches
mad4x4
posted on 6/3/09 at 07:54 AM Reply With Quote
We used the Maplin type ones.
RS used to do them with a light in the back to make em light up
Scot's do it better in Kilts.
posted on 6/3/09 at 12:34 PM Reply With Quote
The Maplin ones look nice - but I fancy having "start" on the button!
Just placed an order for the CBS one.
jabbahutt
posted on 13/10/09 at 09:38 AM Reply With Quote
Quick question on the switch pictured from CBS. How are the wires attached to the switch?
Nigel
posted on 13/10/09 at 11:12 AM Reply With Quote
Good question!
I've forgotten, so I'll have a look tonight (still haven't fitted it, 'cos it'll only work on a thin panel, and my dash is too thick.)
Ninehigh
posted on 13/10/09 at 09:09 PM Reply With Quote
Do they have one marked "Blast off"?
posted on 13/10/09 at 09:35 PM Reply With Quote
Update on the connectors - it has 4 reasonably chunky screw terminals, 2 for the switch itself, plus 2 for the LED backlight. The backlight is very voltage-tolerant, and can be wired directly to a car's +ve supply (either way around).
As I said earlier - there is a limit on the panel thickness, which I'd guess to be around 4 or 5mm.
neilj37
posted on 14/10/09 at 05:44 AM Reply With Quote
I bought mine off ebay, comes complete with wiring and relay. Was easy to wire in and works a treat.
STARTER BUTTON
ken555
posted on 14/10/09 at 11:15 AM Reply With Quote
Question
How do they manage to integrate the on/off and start option into one button ?
At the moment I have a on/off toggle switch and a push start, but would love just have the one button.
wilkingj
posted on 14/10/09 at 01:20 PM Reply With Quote
How will you turn your ignition on and off... ie stop the car with only a start button?
You need to be able to turn the ignition (fuel pump, fire up the Tacho / instruments etc) separately to being able to turn over the engine. Do you always want to start the engine, when using your single button idea? How will you cope with just wanting the ignition on and the engine not running, say for faulting the electics, or just checking the fuel level or other mundane tasks?
Its two operations, and IMHO requires two separate switching functions.
I suppose you could do it with some clever electronics to toggle the ignition when pressing the start button. However this would lead to some interesting moments, when the cars does not start (for some other reason), and you repeately press the button, thus toggling the ignition on and off every time when you just want to turn the engine over and start it. It would need some careful thinking about.
An Ignition switch, and a Start Engine button is FAR simpler, and going to be more reliable.
Dont make it any more complicated than it needs to be. There is a HUGE amount to be said for the KISS principle (Keep It Simple Stupid)
IMHO a column mounted Key for the ignition, and steering lock. Then a press button for the starter circuit. Very simple to do, and retains some security.
Further to that, I would connect A VERY BIG Red "Start" button to the Instant Alarm connection on my car, and use an unmarked or a buttom marked "Oil Level" of some other marking that you wouldnt normally press as the real start button.
Just my 2d's worth.
Best Regards
Geoff
http://www.v8viento.co.uk
scudderfish
posted on 14/10/09 at 02:15 PM Reply With Quote
Isn't the noise of your engine firing up alarm enough?
posted on 14/10/09 at 04:21 PM Reply With Quote
I think the intention was to warn that someone is attempting to start the car as opposed to knowing that they succeded and are about to drive away..... but I guess you knew that ...
<<  1    2  >>
