Author: Subject: Preparing GRP panels for painting
Steelman
posted on 11/3/09 at 08:24 AM Reply With Quote
After dewaxing and flatting off with wet & dry, which type of primer should I use - Etching or normal
Mr Whippy
posted on 11/3/09 at 08:29 AM Reply With Quote
use a good quality etch primer and don't flatten the GRP suface too much, 400 grade is as fine as you really want to go as the primer will have a better key
ordinary primer will come off in sheets
Paul TigerB6
posted on 11/3/09 at 09:08 AM Reply With Quote
As above, etc primer on a keyed surface worked for me.
Halfords actually sell "Plastic primer" in cans which is advertised for use on fibreglass as well as plastic. Has anyone tried this??
Mr Whippy
posted on 11/3/09 at 09:24 AM Reply With Quote
yeah the halfords one works fine, I primered the falcons wings in it and it showed no sighs of a bad bond. Use light dust coats at first, then build up the primer thickness and flatten it with 600 grade ready for the colour coats
