Author: Subject: weight saving
jamrogers
posted on 13/3/09 at 01:30 PM Reply With Quote
weight saving
I'm looking at ways to save weight on my new () tiger avon ( 2 litre zetec ).
Before we go into the go on a diet jokes I only weigh 10 and a half stone.
The car weighs 520 kg with a full tank (withought me in it)
So far i have a rs2000 alloy bell housing.
I am looking for a smaller battery.
I have the 2litre zetec flywheel and am looking for the 1.8 one.
I have no windscreen or washers wipers heater etc. and the standard tiger radiator (is the polo one lighter)?
Can people make some recomendations to save weight stating the weights of standard and replacement parts. I will document it on my website as and when i make the changes, showing the weight saving and the difference it makes to acceleration.
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
owelly
posted on 13/3/09 at 01:32 PM Reply With Quote
What tyres are you using? The avon race tyres I have are very light!
http://www.ppcmag.co.uk
jamrogers
posted on 13/3/09 at 01:34 PM Reply With Quote
i'm using yokohomas. can you tell me the weight of your tyres?
incidently i weighed the 2l flywheel (no clutch or pressure plate) and it came in at 9.8kg
[Edited on 13/3/09 by jamrogers]
YouTube
omega0684
posted on 13/3/09 at 01:38 PM Reply With Quote
lightened flywheel
no boot
lighter tyres and alloys
start getting things made in carbon fibre
hi-spec or wilwood superlight calipers
Dangle_kt
posted on 13/3/09 at 01:39 PM Reply With Quote
what seats?
l0rd
posted on 13/3/09 at 01:43 PM Reply With Quote
half the oil saves about 2kg
half the water saves about 3Kg
remove 2 studs from each wheel will save you 200 grams
take the battery out will save about 8kg
If you have multispoke alloys you can always cut of some saving of 3-10 Kg
Smaller tank, will save you about 10Kg on fuel
That's about it.
big_wasa
posted on 13/3/09 at 01:51 PM Reply With Quote
changing the flywheel will mean a smaller clutch.
You can get lighter than the 1.8 by using a cvh flywheel and mounting a trigger wheel on the front pulley.
You can get yours lightened and balanced.
Scholar engines did mine. Pic in my archive.
afj
posted on 13/3/09 at 02:00 PM Reply With Quote
put a bike engine in
eerrrrrrrrrrrrrrrr
l0rd
posted on 13/3/09 at 02:30 PM Reply With Quote
Now being serious
1st Change alloys and tyres
2nd Flywheel
3rd Seats
4th Calipers
andylancaster3000
posted on 13/3/09 at 02:52 PM Reply With Quote
Try and get the unsprung and then rotating things down in weight first to see the biggest gains.
[Edited on 13/3/09 by andylancaster3000]
posted on 13/3/09 at 03:14 PM Reply With Quote
Littel Red top 20 or 25 should save you a fair bit. Got one on mine with no problems for the last 2 years.
Paul TigerB6
posted on 13/3/09 at 03:36 PM Reply With Quote
Odyssey PC545 battery (starts a 2L Pinto fine)
Alloy hubs and maybe uprights if you feel really flush
Alloy calipers
13" wheels n tyres
Strip the carpets and trim out. Fit fibreglass seats
Stop eating pies
Smaller alternator (Nippondenso etc)
Polo radiator (the heavy Tiger one has steel tanks and WILL rust and then fail)
oldtimer
posted on 13/3/09 at 03:52 PM Reply With Quote
I sold 17" wheels+tyres which were 22.5kg each and got 13" wheels+tyres at 11kg each. Ditched my comfy 7.5 kg cobra seats and got skinny GRP ones at 2.1 kg. I have raceleda uprights to fit and an ally fuel tank, race battery, 80 kg 4age motor and alloy bodied quaife gearbox. It all adds up - or takes away, if you get my drift.
posted on 13/3/09 at 04:28 PM Reply With Quote
Lightweight GRP Kit?
Humbug
posted on 13/3/09 at 06:05 PM Reply With Quote
or remove the bodywork and go Atom-stylee?
Daimo_45
posted on 13/3/09 at 07:08 PM Reply With Quote
Rudy
posted on 15/3/09 at 08:09 AM Reply With Quote
My advice is waith.
Enjoy your setup for some time and when you will change it you will appreciate and feel the difference better.
Sorry about my English
andrew.carwithen
posted on 15/3/09 at 08:41 AM Reply With Quote
TBH, I'd say that 520KG for a zetec-engined Avon is pretty damn light anyway! (Don't Tiger quote something like 595kg for a zetec Avon in their spec. sheet?)
I'd ditch the Tiger rad anyway in favour of the Polo rad (they have been known to leak and are significantly heavier due to steel/copper construction compared to the aluminium/plastic of the Polo.) The polo rad also sits upright within the nosecone and probably offers more efficient cooling. (you would have to make suitable brackets in order to fit.)
[Edited on 15/3/09 by andrew.carwithen]
jamrogers
posted on 15/3/09 at 02:48 PM Reply With Quote
I recon its so light as i have no screen, heater, washers wipers etc and kept the creature comforts to a minimum.
I recon i can save 10kg just on the battery as i have a large one fitted at the moment.
YouTube
icecarver
posted on 17/3/09 at 11:13 AM Reply With Quote
weight
520kg, I have a bec Avon that weights 535kg
with every thing ali possible.
Don't waste your cash ! or check your scales !
ryanslaney
posted on 24/3/09 at 11:11 PM Reply With Quote
Thats pretty light!. My race car avon weighs in at 615kg and it has nothing in it!
