Author: Subject: LED lighting
james h
posted on 23/3/09 at 05:13 PM Reply With Quote
LED lighting
I'm intending to use LED lighting all round my car, except for the headlights.
I am aware that using a standard loom, I will need to correct the indicator flash rate. As far as I can see from searches on here, there are two options for this:
-LED flasher relay
-Inline resistor
I want to use the inline resistors, as it seems it will be a simpler solution. Any opinions on this?
Also, is there anything else I need to be aware of before I start getting all the lights?
Indicators
Rear lights
Any suggestions for rear LED fog lights?
Thanks,
James
blakep82
posted on 23/3/09 at 05:23 PM Reply With Quote
i made a post last week about LED flasher relays. apparently, standard flasher relays can be modified to stop them flashing too quick.
http://www.locostbuilders.co.uk/viewthread.php?tid=108987
it seems a simple case of removing one of the pins from the electronics in the flasher.
on the issue of changing to a led flasher or putting inline fuses. it would be cheaper and easier to just go with an led flasher relay wouldn't it? you can get them for about £8
[Edited on 23/3/09 by blakep82]
________________________
adithorp
posted on 23/3/09 at 05:27 PM Reply With Quote
Use an electronic flasher unit.
Resistors is just a bodge. They draw the same current as using bulbs and get hot so whats the point?
adrian
http://jpsc.org.uk/forum/
serieslandy
posted on 23/3/09 at 05:35 PM Reply With Quote
I would have thought that the led flasher unit would have been the simplist answer as it should be a direct replacement.
Also I would check if the trailer lights are "E" marked as someone was selling a set eariler in the week. HERE
[Edited on 23/3/09 by serieslandy]
blakep82
posted on 23/3/09 at 05:36 PM Reply With Quote
YES those lights are e-marked. i've got some
Paul TigerB6
posted on 23/3/09 at 05:41 PM Reply With Quote
As above - dont bodge it for the sake of an £8 relay. The resistors can generate a lot of heat
posted on 23/3/09 at 05:51 PM Reply With Quote
The resistors have to generate lots of heat. This means your alternator has to work harder. That takes power.
Use a flasher relay.
james h
posted on 23/3/09 at 05:53 PM Reply With Quote
Ok thanks for your replies, a flasher relay it is!
Thanks,
James
splitrivet
posted on 23/3/09 at 06:46 PM Reply With Quote
Those rear lights are smart, wish I hadnt cut flaming big holes in my wings now.
Bob
