Author: Subject: I've just about had enough
clairetoo
posted on 2/4/09 at 04:19 PM Reply With Quote
I'm finally ready to admit defeat
No matter what I check or change , I cant get my car running right on the megasquirt . Every time I drive it , the AFR is different - it will vary at tickover from one minute to the next , it pops and farts constantly (telling me it's way too weak) while the freshly recalibrated LC1 is telling me it's way too rich .
Holding a constant speed/throttle opening and going up and down with the fueling has very little effect - as does doing the same with ignition timing (I've tried going from 1 degree up to 50 degrees and nothing changes )
And less than 20 MPG is killing me - no matter how it's driven .
I have run out of ideas
Its cuz I is blond , innit
Claire xx
Will weld for food......
John Bonnett
posted on 2/4/09 at 04:24 PM Reply With Quote
Claire is it possible that one of the components is constantly changing its value. I had a silimilar problem with a throttle pot on my Jenveys. Each time I took a measurement it was different. Changed the pot, problem solved.
hth
John
MkIndy7
posted on 2/4/09 at 04:44 PM Reply With Quote
Your saying the exhaust is popping indicating its lean, yet the AFR saying its too rich can happen.
Mine was doing it last night, trust your instincts and up the REQ_Fuel or VE.
I'd leave the timing on a pretty standard base map setting so you know its about right or should be, try and concentrate on 1 thing at once.
And yeh i've had about enough of mine too! I'd love somebody to do a really good definitive book with simple terms in it as the megasquirt manual you either seem to get it or you don't.
There's so many simple things that could be done to the software to make it more easily understandable like even the axis putting on the tuning graphs so when its jumping around you can see whats changing.
Could the TB's be too big, or the sharp throttle angle is causing the poor MPG, if the throttle opens too far too soon before the engine rev's up, all you see if the AFR go lean so you and loads more fuel to make it correct.
theconrodkid
posted on 2/4/09 at 05:09 PM Reply With Quote
sounds like the lambda sensor or its connexions,iirc you should get a gently fluctuating ac voltage on the 2 wires that are not heater
who cares who wins
pass the pork pies
GregSL75
posted on 2/4/09 at 05:11 PM Reply With Quote
You want Megatunix, far easier to use:
http://megatunix.sourceforge.net/screenshots/vetables-tab.php
2.0 XE on GSXR TBs and Megasquirt
mr henderson
posted on 2/4/09 at 05:22 PM Reply With Quote
When something is running as badly as that it does suggest a faulty component. I would be inclined to follow CRK's suggestion and check the lambda sensor first.
John
matnrach
posted on 2/4/09 at 07:37 PM Reply With Quote
If you have tried changing the ignition 50degrees and nothing happens than something is very wrong.
Have you had the ecu connected to the stim recently and tested all the inputs?
have you had a timing light on it? Is the ignition constant if you put a flat ignition map in?
Are the rpm/throttle signals steady?
Do some simple tests like disconnecting each cylinder in turn (plug and injector separately) to see if anything changes
Good luck
theconrodkid
posted on 2/4/09 at 07:54 PM Reply With Quote
if you are running EDIS and the unit goes pop,it reverts to limp home mode and the timing stays at 10 deg,worth a try?
who cares who wins
pass the pork pies
clairetoo
posted on 2/4/09 at 07:56 PM Reply With Quote
Well.............four hours of fiddling.......and I found a major problem
On the Triumph throttle bodies , for some strange reason the opening `load` is on the spring part of the adjuster , not the screw . All seemed OK when checking until I tried very gently opening the throttle with the engine running , and four out of the six butterflies were lagging behind , as the springs compressed !
So with four cable ties holding the adjusters in place , and a new `in-between` cable , as well as a different TPS it is sooooooooooo much better
Just had a quick run out to see what it's like to drive - it still wont drop down to tickover consistently , but at least it drives like a 2.5 V6 should
Claire xx
mr henderson
posted on 2/4/09 at 08:18 PM Reply With Quote
Good news
Time and time again it's been shown that you have to go back through everything, checking, taking nothing for granted, and niine times out of ten it's one thing that is seriously wrong, and when put right, you are nearly there. Just tweaking after that
John
Jenko
posted on 3/4/09 at 02:30 PM Reply With Quote
Get a timing light on the crank pulley, make sure your ignition is advancing.......Also, make sure you are not in closed loop mode and the car is not constantly trying to adjust the fuel.
Sounds like the TB issue will make a big difference, so try hard to get a nice smooth tickover, then go slowly from there on in..
MY BLOG - http://westfieldv8.blogspot.co.uk/
