Author: Subject: cleaning hammerite paint off brushes
omega0684
posted on 2/4/09 at 06:55 PM Reply With Quote
how?
Danozeman
posted on 2/4/09 at 06:57 PM Reply With Quote
Hamerite brush cleaner/thinners. Its rum stuff. Normal thinners or white spirit will have a go.
Dan
Paul TigerB6
posted on 2/4/09 at 06:59 PM Reply With Quote
normal paint thinners should do the job without the huge expense
MikeR
i thought that their is a high risk the silicon that makes the crackle finish won't be completely removed therefore you should be careful what you use the brushes for in future (well thats what i've heard on here about spray systems).
jacko
posted on 2/4/09 at 07:08 PM Reply With Quote
Pack of cheep brushes 10 for pence and through after use
SWW84
posted on 2/4/09 at 07:16 PM Reply With Quote
Gunwash
maskell01
posted on 2/4/09 at 07:20 PM Reply With Quote
Petrol
Staple balls
posted on 2/4/09 at 07:22 PM Reply With Quote
Fire.
posted on 2/4/09 at 07:32 PM Reply With Quote
I buy a decent but cheap brush and dump it afterwards.
tommyab
White spirit does it if its immediately after painting.
Dingz
posted on 2/4/09 at 07:38 PM Reply With Quote
Acetone
stevec
posted on 2/4/09 at 07:47 PM Reply With Quote
Napalm,
Just bin em you tight git.
Steve.
flak monkey
posted on 2/4/09 at 08:47 PM Reply With Quote
Celly thinners is what hammerite thinners is.
Cheap gunwash is the same stuff, so I use that Its about a fiver for a gallon at my local bodyshop!
Sera
http://www.motosera.com
dhutch
posted on 2/4/09 at 11:16 PM Reply With Quote
I think Hammerite thinners is actaully xylene isnt it, which if you want a lot fairly cheaply is also used for denaturing epoxy resins.
- Although as said, cellulose thinners will also thin it and is proberbly as good for washing brushes if not thinning the paint for spraying etc as it proberbly doesnt do the paint any good.
Daniel
yellow melos
posted on 3/4/09 at 06:51 AM Reply With Quote
Cheep nrushes, only put in about quarter of the brush when painting, let it dry.. cut off the quarter... get a few uses out of them
Locost to the extream
