Author: Subject: Front end change..
lee_leggett
posted on 3/4/09 at 06:49 PM Reply With Quote
Front end change..
Right all, I have a small dutton Pheaton, running i believe Triumph front suspension and front drums, however the car has ford wheels, are these a stud match or could i poss have ford front drums? I would like to uprate to discs but am not sure what i would need...
minitici
posted on 3/4/09 at 06:53 PM Reply With Quote
You can get alloy conversion hubs for triumph (disc brake) front uprights. They fit the Triumph spindles but have Ford pcd wheel studs.
Merlin
[Edited on 3/4/09 by minitici]
g.gilo
posted on 3/4/09 at 10:45 PM Reply With Quote
hubs
measure from a stud centre through the hub centre to the oposite stud centre?
ford = 4 and a quarter inches
triumph = 3 and three quarters
its called the p.c.d. pitch circle diameter if your not in to engineering
regards graham
dodgedartgt
posted on 4/4/09 at 01:11 AM Reply With Quote
pcd
Hey g.gilo,
Thnx for the definition. As a Yank, we call it 'bolt pattern'. As in Triumph, 4 on 3-3/4", Ford, 4 on 4-1/4",etc
Mike
