Author: Subject: C20XE Crank Pulley Diameter
cd.thomson
posted on 14/4/09 at 10:27 AM Reply With Quote
Hi guys,
this is for the redtop lovers . I'm not at home for a little while but need to get a trigger wheel ordered ready for the engine fit when im back in a couple of weeks. Does anyone happen to know the diameter of the C20XE crank pulley as I was going to buy a ring type?
Also whats the best way of attaching these, someone has destroyed one of the bolts on the front of the pulley so getting it off will be a nightmare (no it wasnt me ) and I cant weld...
thanks as always
[Edited on 14/4/09 by cd.thomson]
Craig
corpi
posted on 14/4/09 at 11:05 AM Reply With Quote
I could measure tonight, but Why not use the existing trigger and VR sensor that is built into the engine?
cd.thomson
posted on 14/4/09 at 11:22 AM Reply With Quote
I'd be very grateful corpi.
For ease I am setting up an EDIS system which I believe doesnt work with the 60-2 trigger wheel found inside the XE engine.
Craig
corpi
posted on 14/4/09 at 07:54 PM Reply With Quote
Mine is a double pulley:
largest OD = 150 mm
OD of smaller pulley = 129 mm
I hope this is what you where after? otherwise let me know and i'll measure some more
Pieter
cd.thomson
posted on 16/4/09 at 10:37 AM Reply With Quote
No thats perfect Corpi, trigger wheel ordered and its way,
many thanks
Craig
