Author: Subject: Alternative handbrake lever position?
Mave
posted on 16/4/09 at 07:52 PM Reply With Quote
I'm considering moving the handbrake lever in my car more to the front, and at an angle, so the handle itself is right next to the gearstick. Just like in the TVR below.
My main goal is to have it easier to operate (without knocking my passengers' teeth out), give some elbowroom for cruizinnn (however, I hardly use that place as such), and make lockable compartment in its current location.
Any pro's and con's I haven't thought of?!?!
mr_pr
posted on 16/4/09 at 08:00 PM Reply With Quote
The boys at Mac#1 drop it into the tunnel so when off it is out of the way... like this...
My Build Progress
adam1985
posted on 16/4/09 at 08:14 PM Reply With Quote
seen this before didnt know its normal on mac1s nice little touch i think
Guinness
posted on 16/4/09 at 08:31 PM Reply With Quote
Nice idea.
Just make sure you can operate it when you are seat belted in.
My mate has a Caterham with a handbrake under the dash on the passenger side. It was fine when he had inertia reel seat belts, but became a problem when he upgraded to 4 point harnesses!
Mike
SWW84
posted on 16/4/09 at 10:14 PM Reply With Quote
How about under the dash on the drivers side like the early Dax Rush?
omega0684
posted on 16/4/09 at 11:31 PM Reply With Quote
^^^^^^ mine is like this , its crap for doing hand brake turns though
Mave
posted on 17/4/09 at 05:56 AM Reply With Quote
I really like the Mac#1 solution, but it won't solve the "elbow in passengers' face" issue I'm experiencing with my current set-up. (at 6ft5 I the associated really long arms )
I have also considered putting it under the steeringwheel, but as you say; I won't be able to reach it with my 4 point harness on.
JAG
posted on 17/4/09 at 07:05 AM Reply With Quote
How about this, ignore the cat
Cat in Q91XAB
Cat in Q91XAB
I also have a small cubby hole in the top of the tunnel which is very useful.
Justin
jabbahutt
posted on 17/4/09 at 07:30 AM Reply With Quote
BBWales has a cracking solution. He's fitted a small T handle in the dash that locks when twisted through a quarter turn. So he pulls it to engage and twists to keep it engaged. To disengage he simplys untwists it and off he goes.
Cracking idea and saveas loads of space in the tunnel area.
sickbag
posted on 17/4/09 at 09:51 AM Reply With Quote
Pretty much the same as the series1 & 2 XJ6s if I remember correctly. Might even be able to find one in the breakers.
Finally back on the job!
quadra
posted on 18/4/09 at 03:58 PM Reply With Quote
Mave
How about cutting your arm off at the elbow and welding your hand back on, no more elbows in face.
Seriously though, don't go for the under the steering column like the Dax, its a pain and difficult to use and easy to leave on without noticing.
You don't need eyes to see, you need vision!
Mark Allanson
posted on 18/4/09 at 08:39 PM Reply With Quote
Cat in Q91XAB
Cat in Q91XAB
That isn't a cat, its a standard silencer
dogwood
posted on 19/4/09 at 07:10 AM Reply With Quote
FREE THE ROADSTER ONE…!!
Ninehigh
posted on 21/4/09 at 06:06 PM Reply With Quote
Don't know how legal/possible/easy to use it'll be, but how about on the dashboard, somewhere behind the steering wheel-ish? There wouldn't be anything sticking out to be impaled on unless you're driving with the handbrake on
Mave
posted on 21/4/09 at 06:34 PM Reply With Quote
Mike, I can't reach the steering wheel if I do that. Oh, and you're to blame for my rebuild and holey quest for more power....
I also like the vertical solution, but how do you connect the cable? Or what lever are you using?
[Edited on 21/4/09 by Mave]
Ninehigh
posted on 21/4/09 at 06:37 PM Reply With Quote
I guess you could use the same lever, and extend the cable by a few foot to reach that extra distance
Marcus
posted on 21/4/09 at 08:52 PM Reply With Quote
If you can find an MR2 handbrake lever, they mount to the side of the tunnel, as does MG Midget. I went for Toyota and used the Toyota first cable to pull a balance bar and a cable (Allegro) to each back wheel.
Marcus
Because kits are for girls!!
rb968
posted on 24/4/09 at 01:25 PM Reply With Quote
Or like a Citroen GS which was a handle you pulled straight out of the dash. Just sat in a recess. My Gran had one. Not sure you'll find one in a scrappy though!
Rich
