Author: Subject: Immobiliser
Bigheppy
posted on 19/4/09 at 10:17 PM Reply With Quote
Immobiliser
Just read the IVA article in complete kitcar and am wondering what sort of immobiliser can be fitted to kit cars, which installers would be interested and how much is it likley to cost.
muzchap
posted on 19/4/09 at 10:21 PM Reply With Quote
I just got one of those negative battery terminal cut-off switches from Think Auto about £10-£15 IIRC.
Plus the standard sierra steering lock - that was enough.
I cant find a pic of it - but it's got a little green wheel you twist to disconnect the supply to the battery and then screw it back down to reconnect the supply.
That combined with steering lock was good enough for SVA - although 3 years ago
HTH
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
nitram38
posted on 20/4/09 at 05:40 AM Reply With Quote
I think it has to be a minimum of Cat II thatcham (makes your insurance cheaper too).
I bought a Hawk HA-203 on ebay for about £25 and fitted myself.
I got an installer to check my work and issue a cert (required at IVA and by insurers)
mad4x4
posted on 20/4/09 at 06:40 AM Reply With Quote
I just got my Indy insure with Class II thatum.
To them It was factory fitted.... (well I am the factory) and was same on used on Mazda RX 7's.
Scot's do it better in Kilts.
