Author: Subject: MS won't read JAW output
Snuggs
posted on 20/4/09 at 09:37 PM Reply With Quote
Connected JAW Vout2 to MS but not getting any reading on the AFR gauge.
JAW set to emulate LC1
Configurator set to LC1 in settings.ini
EGO set to Single Wideband
Voltage from JAW changes when tested with butane on the lambda sensor.
Gauge works OK using the Stimulator.
Am I missing something obvious or just being stupid ?
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
RichardK
posted on 20/4/09 at 09:43 PM Reply With Quote
Think Tim Windmill nearly got his working, maybe worth a u2u?
Rich
Gallery updated 11/01/2011
tim windmill
posted on 22/4/09 at 11:21 AM Reply With Quote
Snuggs have you got a wire connecting either your Vout1 or Vout2 on your JAW pcb board to your megasquirt O2 signal wire on your db9 connector
Snuggs
posted on 22/4/09 at 11:48 AM Reply With Quote
Hi Tim,
Vout2 is connected to pin 23 on the DB37 connector.
I have been trawling the net for more info on this and I believe I need to change some settings in the ENRICHMENT menu but I cant figure out where this menu is
Voltage out of JAW checks out OK using a multimeter.
Clive
