Author: Subject: steering wheel and QR boss **edit**
eccsmk
posted on 1/5/09 at 03:41 PM Reply With Quote
does anyone know where i can get a 330mm steering wheel in suede for less than £100?
by the time ive got a wheel and boss its knocking on £200 and that only leaves me £50 to build the car
[Edited on 1/5/09 by eccsmk]
stevebubs
posted on 1/5/09 at 03:43 PM Reply With Quote
try Merlin
eccsmk
posted on 1/5/09 at 03:53 PM Reply With Quote
im pleased you suggested them
just had a quick browse they have some racetech ones around the £100 mark.
james h
posted on 1/5/09 at 04:49 PM Reply With Quote
If you aren't so bothered about the make of the wheel, then I would suggest you take a look at Rallydesign's selection.
I have a 320mm formula D steering wheel. I haven't driven the car yet, but I can say it seems about the right size and feel.
eccsmk
posted on 1/5/09 at 05:02 PM Reply With Quote
thank you james
i had a sierra whel first off then a 260mm one and now a 300mm one and with the quick rack fitted its not brilliant so i think 330mm would be about right
eccsmk
posted on 1/5/09 at 05:30 PM Reply With Quote
now ive found a wheel which boss from here will i need to fit my adjustable column?? as they have a bolt in the end rather than being threaded
by the way i chose the d shaped 320mm wheel
bram boekestein
posted on 1/5/09 at 10:02 PM Reply With Quote
You'll need to weld the hex part to your steering column, instead of bolting it on.
eccsmk
posted on 2/5/09 at 12:15 PM Reply With Quote
i know me duck
think im now sorted
thanking yee
