Author: Subject: Megasquirt acceleration enrichments
omega0684
posted on 11/5/09 at 04:13 PM Reply With Quote
went out for a blast this afternoon and noticed that when i accelerate hard the AFR gauge on my megatune screen just goes straight into the lean area of the gauge sometimes maxing out at 20:1, is this down to the acceleration enrichments how do i go about adjusting them.
brianthemagical
posted on 11/5/09 at 04:40 PM Reply With Quote
Are you sure your fueling is correct, and i'd only find out once and never make itthat lean agin, even if it means not driving, it's a recipe for disaster.
Just drive nice and slow with low throttles for a bit, see how that fairs, make sure the fueling os ok for light throttle, then when they're sorted move on to the AE wizard.
What load method are you using?
matnrach
posted on 11/5/09 at 09:39 PM Reply With Quote
I use MAP related enrichment with an engine that has MAP for load control.
I tried throttle rate as the input for accel enrichment but it was much worse.
My experience with throttle body injection (on a siamesed inlet ported engine) that has large amounts of wall wetting is that you need a high value of enrichment for a very short time. A low value for a long time does not fix the initial transient enleanment and then makes it very rich afterwards.
