Author: Subject: Guess the Weight
Nosey
posted on 19/5/09 at 12:16 PM Reply With Quote
Guess the Weight
Bit of fun...
Competition (hillclimb) car, Locost chassis, Cortina uprights & brakes, 2ltr 16v Vauxhall, 4 speed Rocket box, English axle, full cage (3mm wall), built using the following priorities:
1) budget
2) budget
3) weight saving
4) budget
Guess the weight (ready to race without driver)?
cd.thomson
posted on 19/5/09 at 12:19 PM Reply With Quote
600kg?
Craig
Land Locked
posted on 19/5/09 at 12:20 PM Reply With Quote
I'd say optimistically around 450kg.
Howlor
525?
UncleFista
posted on 19/5/09 at 12:25 PM Reply With Quote
580kgs
Tony Bond / UncleFista
andrewcutchey
posted on 19/5/09 at 12:26 PM Reply With Quote
On the basis of going bust if you overstate the weight, I'll go one further, 526?
Staple balls
posted on 19/5/09 at 12:33 PM Reply With Quote
542Kg
Hammerhead
posted on 19/5/09 at 12:50 PM Reply With Quote
475kg
Nosey
posted on 19/5/09 at 12:56 PM Reply With Quote
It's 509kg. Was disappointed, for some reason I really wanted it under 500kgs, 499 would have sounded so much better. Still, it's nothing that a few thousand euros won't fix.....
iank
posted on 19/5/09 at 01:10 PM Reply With Quote
Depending on what you have wheels and tyres have the potential to save well over 9kg (and you have all the advantages of lower unsprung (and better rotating) weight.
Set of Wilwood's instead of the cortina brakes will only help.
Anonymous
speedyxjs
posted on 19/5/09 at 01:28 PM Reply With Quote
420
iank
posted on 19/5/09 at 01:34 PM Reply With Quote
Originally posted by speedyxjs
420
Bet you didn't read the thread before posting
Anonymous
blakep82
posted on 19/5/09 at 01:45 PM Reply With Quote
420
445!
i know....
________________________
omega 24 v6
posted on 19/5/09 at 03:14 PM Reply With Quote
595kg
DarrenW
posted on 19/5/09 at 03:20 PM Reply With Quote
Is that 509Kg with full tank of fuel? If you only put in whats needed to complete the run you might get under 500Kg. Or as said try some lighter wheels. I was surprised what difference it made when i fitted ATS DTC wheels to mine.
Shouldnt be too hard to lose 9Kg. Can you lighten some of the bars in the cage? Changing the brakes might save a little. As you say though it starts to get expensive to make small reductions.
How was it weighed? I often wonder if weigh bridges are accurate at the lower end of the range. I would have thought most are calibrated to take 20T wagons etc. As toolmakers know - micrometers are more accurate if they are set using a setting master that is close to the part being measured, is the same true for weigh bridges etc?
posted on 19/5/09 at 03:27 PM Reply With Quote
Put the driver on a diet... more effective than scratching around trying to save 9kg. In my car the heaviest thing is the nut holding the steering wheel...
There's a very good reason why F1 drivers tend to be small, powerful guys!
[Edited on 19/5/09 by David Jenkins]
iank
posted on 19/5/09 at 03:30 PM Reply With Quote
Depends on the weighbridge, I've read (on here I think) that most are only accurate to within about 10kg.
Cheapest and usually best way to lose weight for competition is to lay off the pies for a month - though that doesn't help with getting below the 500kg mark.
Anonymous
bimbleuk
posted on 19/5/09 at 03:38 PM Reply With Quote
Alloy gearbox housing will save ~5kg. You did say you built it with weight saving in mind but how thin is your GRP body work? I know I can say at least 10kgs if I switched to the lighter GRP body work offered by my kit supplier.
Still pretty good for a CEC though.
[Edited on 19-5-09 by bimbleuk]
fesycresy
posted on 19/5/09 at 04:01 PM Reply With Quote
Tune the motor and eat that kebab
A1
posted on 19/5/09 at 04:17 PM Reply With Quote
take off the silencer, mine weighs 6 kilos!
Nosey
posted on 19/5/09 at 04:26 PM Reply With Quote
I'm 6ft and about 68 kgs, the only way for me to really shed weight is shave my head!
I left off the alternator and have a little bike battery, it starts with a slave battery, so I have tried my best!
I weighed it with 4 cheap weighing scales and accuracy wouldn't be great. Rims, gearbox & diff casings, uprights will all cost me money, so I think it's off to the scrappy to see what alloy calipers might work.
