Author: Subject: water pump failure !! Again
locosaki
posted on 26/5/09 at 02:36 PM Reply With Quote
Hi all,
I have a ZZR1100 and after being out last night my third water pump has packed in,I have been through 2 pumps in 6 weeks,Anybody know what would cause pump failure.
If I rev the engine hard I can get it to circulate briefly but instead of a stream of what returning into the stat housing it gushs lots of water and spits backout the top of stat housing(this all done with rad cap off) Also the colour of the water is dirty brown and I have changed water/anti freeze several times now !!
[Edited on 26/5/09 by locosaki]
dinosaurjuice
posted on 26/5/09 at 02:39 PM Reply With Quote
are you using the right coolant?
silicut free, or glycol free etc.
just an idea.
Mr Whippy
posted on 26/5/09 at 02:41 PM Reply With Quote
Is the radiator even getting hot? sounds like the engines overheating cos the thermostat isn't opening and the over pressure is causing the pump seal to leak.
locosaki
posted on 26/5/09 at 02:56 PM Reply With Quote
I have run car with just water this time,Didn't bother with the anti freeze,The rad is getting hot !
Guinness
posted on 26/5/09 at 05:54 PM Reply With Quote
Sounds very odd.
I understand you have changed the anti-freeze a few times. Have you flushed the cooling system each time? I have just flushed my system one item at a time, radiator / pipework / expansion bottle / block and then all together. There may be a blockage somewhere.
The water pump is pretty simple affair, the keyway on the back goes into the drive shaft off the oil pump. The impeller is fixed to the shaft. How are they failing?
Can you drain down the coolant, take off the inlet or outlet pipe from the pump then turn the engine over? You should be able to see if the impeller is spinning in time with the revs?
What sort of thermostat are you using? Is it worth taking it apart and testing with boiling water?
It sounds like an airlock. Try jacking the car up at the front or back and bleeding it again.
HTH
Mike
mistergrumpy
posted on 26/5/09 at 05:59 PM Reply With Quote
I've drained the system on my ZX9 loads and use deionised water and anti freeze but it still comes out brown.
locosaki
posted on 26/5/09 at 06:38 PM Reply With Quote
I've just removed the thermostat run it up to 102 degrees,I then bridged the fan out and the temp dropped away down to what I would consider normal,I assumed the water pump as I could not see the water circulate yesterday and when I did rev the car the water shot out of the filler from what I have gathered tonight the over heating problem could have been caused by a faulty stat but I have only checked when the car is ticking over,I don't have a header tank on mine,Is it a better idea to plumb one in ?
Mike
snapper
Only a passing thought but perhaps the radiator is still full of rust sludge and as this circulates its causing problems with the pump bearings.
Only solution is rad flush and hose it untill it runs clear.
Once you get clear water it should be fine
I eat to survive
I drink to forget
Guinness
posted on 27/5/09 at 06:50 AM Reply With Quote
Mike
I'll take a photo of my install later, but I have the original ZZR1100 C thermostat installed just in front of the cylinder head. (The D won't work it's integrated into the frame). There is an 6mm outlet from the top of the thermostat housing that goes to an unpresurised expansion tank, mounted on the bulkhead. Any expansion gets pushed in there and when the system cools, it sucks it back in.
How have you got it plumbed in? Mine is in short sections of silcone hose and long ally pipes. I can feel the difference in temperature between the top pipe and the lower pipe.
Is there any chance you could replace a section of hose with some 25mm clear hose? This would allow you to see that it is circulating properly.
Mike
mad-butcher
posted on 27/5/09 at 07:49 AM Reply With Quote
The way to check a thermostat is suspend it on a piece of string in a pan of water with a thermometer in bring to boil and see if thermostat opens at desired temperature, I would have thought a header tank was essential with all bike engined installs also ensure cap matches blow off pressure of original bike one
tony
locosaki
posted on 27/5/09 at 09:38 PM Reply With Quote
I have the c model stat also,I have the 6mm expansion pipe but it just overflows onto the ground I also have another expansion pipe on my rad but if I'm going to fit a header tank I could get away with blocking 6mm pipe from rad and just use the expansion pipe from the stat housing I should imagine.The pipe coming from the bottom of the header tank,Where have you got this plumbed in about ?
Cheers Mike
