Chris_R
| posted on 4/3/04 at 09:48 PM |
Type 9 Hydraulic Clutch
I have recently started work on my build but have yet to start the chassis, the reason being that I need to find out how much I need to lengthen the
cockpit by. Before I can start I need to determine the dimensions of the pedal box, which I would like to fabricate myself. I have decided on a floor
mounted box and would like to use a hydraulic clutch. Does anyone know how this would be done with a Type 9 box?
http://www.chris.renney.dsl.pipex.com/
[Edited on 4/3/04 by Chris_R]
Mark Allanson
| posted on 4/3/04 at 10:11 PM |
Not that I have done it, but with correctly chosen master and slave diameters to give suficient throw, and a suitable strong bracket attached to the
bellhousing bolts, it should be relatively simple
cosworth
| posted on 4/3/04 at 10:30 PM |
You replace the clutch release arm carrier on the front of the box with a bolt on hydraulic unit £65.79 plus VAT for the clutch release unit and
£30.40 plus VAT for the adaptor from info@shawspeed.com
Chris_R
| posted on 4/3/04 at 11:03 PM |
Thanks for your help. Think I'll prolly go for the fabricate a bracket route. Does anyone know of a source of suitable slave cylinders,
specifically make and model?
Friberg
| posted on 5/3/04 at 08:17 AM |
I know that SBD Motorstport sells the Saab 900 slave cylinder (MY 79-93) to their bell houses for using a Ford gearbox to a GM engine so that should
work fine.
dozracing
| posted on 5/3/04 at 11:16 AM |
The saab slave cylinder route is very easily done and much better packaged, so you can move the engine/box rearward in the chassis.
Email me offlist and i'll help you with all the components required.
darren@gtstuning.co.uk
Kind regards,
Darren
Chris_R
| posted on 6/3/04 at 07:17 PM |
thank all for you ideas, big help.
ned
| posted on 8/3/04 at 10:02 AM |
I bought an old type 9 box off ebay for its hydraulic slave cylinder. turned out to be a tilton one i think:
Ned.
beware, I've got yellow skin
| posted on 13/3/04 at 01:31 PM |
I have been looking at slave cylinders and the Rover 600 (Honda powered versions) has a cylinder the should bolt on without much trouble --- no as
satisfactory as the Saab route but easier as it all on the outside --- same source looks good for a master cyliner and resevoir.
