Author: Subject: Type 9 jumps out of 5th
bonerp
posted on 5/3/04 at 08:55 PM Reply With Quote
Any ideas? Its supposed to be a recon box but when I put it in it pops out again!
I have a westie remote too.
Wondering whether the gearstick might be over worn?
On a pinto by the way.
Paul
Simon
posted on 6/3/04 at 12:35 AM Reply With Quote
Paul,
I guess that first thing to check is selector. If poss try adjusting to see if you can get more movement into 5th (ie push it further into gear - could be gears are only just engaging).
If that doesn't work, contact the seller - presumably as it's recon, you bought from commercial outfit. They can then replace it (Sale of Goods Act).
If private purchase then Caveat Emptor and Uberimar Fides(sp?) spring to mind I'm afraid.
Simon
