Author: Subject: R1, Westfield, GAZ Shocks.... lethal sump height !
Major Stare
posted on 7/6/09 at 06:10 PM Reply With Quote
Got the Westfield back from having its R1 fitted (used to be a X-flow).
The standard SPAX are tired and the front ride height was too high.
Today i fitted some GAZ shocks from a mates Blade Westfield.
Here's my problem.....
The sump is now just 3" off the floor
What kind of height are others running? Is it too low?
Jon "FISH"
speedyxjs
posted on 7/6/09 at 06:15 PM Reply With Quote
Im going to run about 6" between chassis and ground (sump hangs about 2" below chassis) but i believe most run 4" between chassis and ground
easisatman
posted on 7/6/09 at 06:26 PM Reply With Quote
yep my striker with a R1 engine is about 4 inches from the ground well to the sump shield! You will need a sump shield!. Those little speed humps are the worse.
regards
paul
Stuart_B
posted on 7/6/09 at 06:34 PM Reply With Quote
i have about 3" to 4" from ground
stuart
Flamez
posted on 7/6/09 at 06:36 PM Reply With Quote
zx10r around 3"
my build mac1motorsports
andrew.carwithen
posted on 7/6/09 at 06:39 PM Reply With Quote
I have 65mm sump clearance which is less than 3" (and that's without me sat in it!) I have only lightly grounded it once on a speed bump in work. (I just avoid routes with them on the highway)
Major Stare
posted on 7/6/09 at 06:40 PM Reply With Quote
3" seems a little concerning but as others are running a similar height, it cant be that bad?
easisatman, did you make the sump gaurd? any pics?
Jon "FISH"
Richard Quinn
posted on 7/6/09 at 06:53 PM Reply With Quote
About 5" (but that's one of the advantages of a dry sump)
Jon Ison
posted on 7/6/09 at 06:58 PM Reply With Quote
Make a sump guard you will be ok.
5" ground clearance ? Your not taking full advantage of the dry sump, lower the engine and lower the cog....
eccsmk
posted on 7/6/09 at 07:40 PM Reply With Quote
ive just measured mine
3.5" from sump to floor
i can drive over those rubber bolt down spped bump jobbies without too much hassle
HTH
flak monkey
posted on 7/6/09 at 08:01 PM Reply With Quote
3" to my pinto one, not grounded it yet....
Sera
http://www.motosera.com
richard thomas
posted on 7/6/09 at 08:05 PM Reply With Quote
mine's about 4 fingers....no probs, just needs forward planning.
got on and off a ferry no probs, that was my biggest worry to date!
smart51
posted on 7/6/09 at 09:27 PM Reply With Quote
The vortx has 100mm of clearance between the chassis rails and the floor. My R1 sump hangs a little below this. So long as you are careful with speed humps you might be OK.
Guinness
posted on 7/6/09 at 09:29 PM Reply With Quote
The underside of my chassis rail between the front wishbones is 120mm from the floor. The same measure at the back is 140mm.
The sump drain plug is the only thing that sticks down below the chassis rails. The last time I changed the oil, the sump plug had a few parallel scores on the head of the bolt.
No problems with speed humps or big air!
Mike
dhutch
posted on 7/6/09 at 09:30 PM Reply With Quote
I currently have around 4inchs chassis to ground, leaving about 2 inchs sump to ground.
- It works, and i basically dont hit it on anything. But at the same time im very glad its a pressed steel sump. And i am planning to shorten it or swap it for a shorten one as soon as i conveniently can.
Daniel
Richard Quinn
posted on 7/6/09 at 09:57 PM Reply With Quote
Actually I have since measured it and it's closer to 4". I find it really usefull in those unplanned excursions into the scenery!
easisatman
posted on 9/6/09 at 10:54 AM Reply With Quote
Here you go major stare some pics and the last one to pis* you all off its somthing called sunshine lol.
the guy who built my striker told me when he went to le mans coming out of the car park he hit a rock and resulted in hole in sump and all oil on the floor !! so he made the sump sheild, the speed humps that are a problem are the short bolt down type as you go over them you can just feel the sump sheild touch -see pics with the black rubber marks!! and you can see a lot of other scratches, so they are worth fitting
regards
Paul
easisatman
posted on 9/6/09 at 10:58 AM Reply With Quote
easisatman
posted on 9/6/09 at 11:00 AM Reply With Quote
easisatman
posted on 9/6/09 at 11:05 AM Reply With Quote
