Big Ali D
| posted on 14/6/09 at 10:40 AM |
Xbox Elite, Expensive doorstop?
I have just bought a Elite with a faulty dvd drive, It will play movies and cd's but if you put a game in it says ""TO PLAY THIS
DISK PUT IT IN A XBOX 360 CONSOLE".
I have been told i need to re-flash the drive. Has anyone done this or knows a good website with instructions for idiots?
chris_smith
| posted on 14/6/09 at 10:47 AM |
should have got a PS3
Big Ali D
| posted on 14/6/09 at 10:49 AM |
Could'nt get a PS3 for £30
Ferg
| posted on 14/6/09 at 10:58 AM |
My Xbox geek son tells me it's not easy, but recommends
www.gcmods.co.uk
HTH
Dangle_kt
| posted on 14/6/09 at 10:59 AM |
that might be the reason it was £30
I'd just invest an hour on google, you'll find a relevant forum or similar with a search function you can rummage through.
paul the 6th
| posted on 14/6/09 at 11:46 AM |
try some of these
http://www.google.co.uk/search?hl=en&q=xbox+mods&btnG=Google+Search&meta=&aq=f&oq=
seems to be a well tread path so have a good read up and I'm sure you'll find the answer
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
Ninehigh
| posted on 15/6/09 at 11:04 PM |
Sorry you've got an Xbox that's telling you to put an Xbox game in an Xbox?
No matter how broken it is that's retarded and Mr Gates should be told. Go to www.saynoto0870.co.uk (or it might be .com) and look up microsoft.
I know it's there somewhere
| posted on 16/6/09 at 07:55 AM |
Sounds like someone's been attempting to "softmod" it to play copies, and it's gone horribly wrong.
trogdor
| posted on 18/6/09 at 09:37 AM |
it sounds like the hard drive needs rebuilding, or your eprom needs fixing.
You can do all this on the original xbox, I have mine running linux. I know nothing about the xbox 360 but i would of thought there is someone who can
help in a forum somewhere.
There was a cd that you could use in your xbox to rebuild your harddrive for you. hopefully something similar exists for the elite
Ninehigh
| posted on 24/6/09 at 02:29 PM |
Iirc the only difference between the normal one and the elite is the black case and hard drive size
