Author: Subject: Stopping the steering flapping
speedyxjs
posted on 20/6/09 at 06:47 PM Reply With Quote
What can i use to hold the steering column in place. Iv been looking at rose joints but none i have looked at say what the internal diameter is (my steering shaft is 16mm).
blakep82
posted on 20/6/09 at 06:51 PM Reply With Quote
http://www.mcgillmotorsports.co.uk/index.php?act=viewProd&productId=20
these ones are 16mm hole
[Edited on 20/6/09 by blakep82]
________________________
speedyxjs
posted on 20/6/09 at 07:10 PM Reply With Quote
Cheers. Do you think it will be a problem if the joint cant be removed without having to cut the shaft as i need to weld it to the uj?
omega0684
posted on 20/6/09 at 07:27 PM Reply With Quote
what you want is one of THESE
speedyxjs
posted on 20/6/09 at 07:31 PM Reply With Quote
The bore size is 1".
andyd
posted on 20/6/09 at 07:34 PM Reply With Quote
I'm sure he meant one of THESE
omega0684
posted on 20/6/09 at 07:37 PM Reply With Quote
a thank you
speedyxjs
posted on 20/6/09 at 07:40 PM Reply With Quote
Oh right. Didnt see them on the site
