New Topic New Reply
Author: Subject: DRIVING TO TRACKDAYS
matt.c
posted on 22/6/09 at 08:33 PM Reply With Quote
After spending an evening at snetterton watching a bike track day im now really tempted to take the indy but i have one major problem, No trailer and no tow car.
How many people have driven there cars to trackdays then hammered them around all day then driven home?
Have you enjoyed the day? Ie not worried about braking down.
Cant hire towcars and trailers as money is tight.
Steve Hignett
posted on 22/6/09 at 08:36 PM Reply With Quote
I rode a carbon fibre fairing-ed bike with no seat all the way to the Nurburgring and back...
So I'm pretty sure you could get to a TD and back mate
eccsmk
posted on 22/6/09 at 08:40 PM Reply With Quote
i'll trailer it to and from if you want.
just let me know when and where
posted on 22/6/09 at 08:58 PM Reply With Quote
I've both driven and trailered mine, all I can see is taking the trailer is handy if you bin it
Trailer had the advantage of extra fuel, tools etc but that was before SVA so was very cautious/equipped.
Just remember you need lots of petrol, a jerry can maybe. I used two full tanks the last time I was out and it is 30 litres a time in mine!
Compared to 40mpg on the road it was an eye opener
locoR1
posted on 22/6/09 at 09:01 PM Reply With Quote
Two weeks today i will be driving to Belgium along with 6 other sevens so seven sevens
On the Wednesday we have a track session booked at Zolder don't plan to be driving flat out but you know exactly what's going to happen if someone comes past just hope we make it home ok.
Just join the AA they took a certain member on here home from santa pod with a broken half shaft without even questioning it!
Check out my CB500T Cafe Racer build diary
mark chandler
posted on 22/6/09 at 09:14 PM Reply With Quote
Get recovery, drive there, if you bust it they will pick you up, I know
Guinness
posted on 22/6/09 at 09:18 PM Reply With Quote
I've done about half a dozen trackdays at Teesside, which is a 45 mile drive from home.
I've never really worried about breaking down (any more than I do normally). If I bin it then I'm in trouble either way. If it breaks down (and I couldn't fix it myself), then I'm sure one of the marshalls would be able to tow me half a mile from the track before I called the AA!
The only time I have used a trailer was when I did Bruntingthorpe, but that was a 200 mile trip each way for me.
I wouldn't worry about driving there and back TBH.
Mike
JUD
posted on 22/6/09 at 09:19 PM Reply With Quote
As Coozer says - trailer is really useful if you need to bring the car back in bits
I have had 1 terminal failure at a TD - exhaust weld disintegrated and the silencer parted company with the car. Needless to say that ended the TD for me as I was already struggling with the drive by noise metre before the exhaust failed
Driving 100 miles home in an exhaustless BEC would have been a bit noisy , so thank god for a trailer.
Frankly if you can't get a tow car/trailer then don't let a "what if" stop you going on a TD. The "what if" may not happen and you will have a great time. If you do have a moment then you can always get recovered home via AA/RAC etc.
Martin
MK Indy Blade
smart51
posted on 22/6/09 at 09:31 PM Reply With Quote
I've driven to 6 track days. I've driven home from 2 of them, limped home from 2 and been taken home on a truck from 2. Green Flag were really good.
On my first trip to Mallory Park, the gear shift cable snapped on my 7th lap. After failing to fix it, I put it into second under the bonnet then drove a few miles from the track and called green flag.
At Elvington I broke 2nd gear (it kept jumping out) so drove home by short shifting through into 3rd.
On the way home from Cadwell Park, the front right top ball joint came loose in the wishbone. I sorted this out in a layby on the unlit A 47 at 10 at night in the dark. As I pulled away, the propshaft came off. The sprocket adapetor nut had come loose. So I got out the spanners and allen keys and put it all back together properly, thread lock and everything. Just as I torqued up the last bolt, the battery, driving the hazzards, ran out. Home on the truck.
At Silverstone, the epoxy bung in the air jet of one of the carbs came off. It would only run on the pilot circuit and made BAD noises on the needles. Limped home. 50 MPH was fine. 60 wasn't.
I'd drive again. Take tools. Buy breakdown cover first.
[Edited on 22-6-2009 by smart51]
Worzey
posted on 22/6/09 at 09:49 PM Reply With Quote
I drove to my last track day at Lydden Hill (approx 80 miles).
As stated watch the fuel, I used about 4 tanks in total 8)
I'm off to Goodwood on the 24th July and will probably trailer the car even though it's much closer.
It's going to be expensive as I have to get a towbar fitted and hire a trailer but as I've just had the engine rebuilt I want to ensure I have all the bases covered.
Caterham R400
ReMan
posted on 22/6/09 at 10:19 PM Reply With Quote
Driven to all mine (4) so far.
Got one booke for mallory, about 10 mins drive from home and I'm more worried about popping it there than I have been anywghere else
madteg
That certain member was me, no questions asked, the AA man said he picked cars up from santapod on a regular basis.
austin man
posted on 22/6/09 at 10:39 PM Reply With Quote
brother in law did 180 miles to Anglessy and a fuul day on the track then drove back zetec engined no problems with cooling, accelerator cable snapped on the way home quick fix in a lay by
MikeR
posted on 22/6/09 at 10:52 PM Reply With Quote
Friend works for the AA. Coming back from mallory PPC day we chatted about this - after we drove past some lads in a car being recovered. Lets just say we're both amazed a striped out track day car broke down a mile from the circuit, in a lay by and his mates with a tow rope attached to the rear of their car just happened to be there!!!
Anyway, AA will not recover race cars, nor will they recover from a track. In theory they won't recover out of a ditch by the side of the road.
So if you make it away from the track and break down & don't be an arse, you'll get recovered. You may get asked politely if you've been racing and .... well, have a guess what you say.
I raised that track days aren't technically racing & he said yeah, but it depends on the mood of the patrol person really so you're better off playing dumb than arguing the point. They're all petrol heads and would rather be playing with a toy car than trying to get a grannies 10 year old micra to start.
whitestu
posted on 23/6/09 at 07:34 AM Reply With Quote
I drove to Lydden Hill and back, which is about 190 miles round trip.
Only problem was a cracked alternator bracket, which didn't actually stop anything from working.
Stu
New Topic New Reply
