Author: Subject: Wanted: pre 1993 1800 zetec
RMarine
posted on 30/6/09 at 10:07 PM Reply With Quote
Wanted: pre 1993 1800 zetec, i will pick up from pretty much anywhere thanks
omega0684
posted on 30/6/09 at 10:08 PM Reply With Quote
trying to get around fitting a CAT r we?
RMarine
posted on 30/6/09 at 10:09 PM Reply With Quote
Yep !!!
UncleFista
posted on 30/6/09 at 10:22 PM Reply With Quote
I bought one recently from an Orion Si, it has no engine number. It's not been ground off or messed with, it's a virgin surface, it's never had one. The only marking is an RQ not even RQA or RQB.
I've since read that in the early days of Zetecs, recon engine's came from Ford without a number.
It makes no difference to us as SVA was years ago, but I wouldn't like to turn up for IVA with an engine with no number.
If you buy one, make sure it has an engine number
Tony Bond / UncleFista
austin man
posted on 30/6/09 at 10:40 PM Reply With Quote
I thought it was pre 95 for the emmisions?? The inspector will struggle to see the number I gave him mine and also a sheet confirming date of build I think there is a site linked on here for the zetechttp://www.zetec-cat.co.uk/ I tink the sheet for age related engines is on the site
drury318
posted on 1/7/09 at 05:37 AM Reply With Quote
As far as I`m aware it`s pre july `92 for a manufacturer`s vehicle, but if there is no exact match in the testing manual for your vehicle then it becomes pre aug `95 that is the cut off date, hence for kits it is the `95 date used? Have a look in the flow charts in the IVA manual, it`s available to download online thru DVLA, Cheers
adithorp
posted on 1/7/09 at 07:56 AM Reply With Quote
Yes, for kit's it's effectivly, manufactured pre 1st Aug' '95.
adrian
http://jpsc.org.uk/forum/
Omni
posted on 1/7/09 at 08:26 AM Reply With Quote
This should be pre 94 as the XR2i's were stopped then I believe
Bay of Fleas
HTH
O
posted on 1/7/09 at 10:28 AM Reply With Quote
sent u2u
