Author: Subject: Avon front geometry
Northy
posted on 1/7/09 at 07:59 AM Reply With Quote
Avon front geometry
Mmmmm, is it right if built as standard?
I've been driving mine to work again for the last couple of weeks after about a 3 year lay-up and it doesn't seem right.
I have a feeling it has some nasty bump-steer (it's all over the place on bumpy roads) and when going round corners the outside tyre squeals.
Anyone care to comment? Anyone changed anything to improve it?
Graham
omega0684
posted on 1/7/09 at 08:13 AM Reply With Quote
has the car been sat in the same spot for 3 years? you my have flat spotted tyres, this ould make steering and the whole ride quite bad
posted on 1/7/09 at 09:38 AM Reply With Quote
The tyre squeal is caused by a basic error in the positioning of the steering rack on the Avon -- if you look down from above the steering rack centre line is a few inches ahead of a imaginary line joining the centres outer track rod ends.
This causes excessive toe-in when cornering made worse by roll steer. This over loads the outside front tyre by putting an excessive slip angle on it and cause the inside front not to contribute to the cornering ----- hence the tyre squeal.
What is actually required is some toe-out when cornering, Ford achieved this on the Mk1/2 Escort and Mk3-5 Cortina by mounting the a couple of inches aft of the imaginary line joining the outer track rod end centres.
Not sure if the layout of the front of the Avon chassis will allow an easy way to rectify this.
Northy
posted on 1/7/09 at 11:04 AM Reply With Quote
Re we talking Ackerman here? As in it has the opposite to Ackerman (outside wheel turns tighter than inside?)
G
[Edited on 1/7/09 by Northy]
Graham
Northy
posted on 1/7/09 at 11:54 AM Reply With Quote
Well, I've just been outside for a look and yes, the outside wheel turns tighter than the inside wheel!
That's BS. Anyone fixed this?
G
Graham
Rudy
posted on 3/7/09 at 06:14 AM Reply With Quote
I have sierra uprights instead of escort and I had antiacheram, I solved this problem repositioning steering rack please read this : http://www.locostbuilders.co.uk/viewthread.php?tid=53010
Sorry about my English
Rudy
posted on 3/7/09 at 06:28 AM Reply With Quote
In the past I asked some Avon owner if they have akcheram or antiacheram and they say ackerham ... now I have some doubt. So Avon owner what do you car have ?
t.j.
posted on 7/7/09 at 09:02 PM Reply With Quote
Oh, Oh...
I did use the steering-rack position....
Should I worry and leave it, Or should I take the grinder?
front clickie
[Edited on 7/7/09 by t.j.]
JacksAvon
posted on 8/7/09 at 09:44 PM Reply With Quote
I raced one for two years and did well with it. It was a standard build, handled great and went like stink
Northy
posted on 23/10/14 at 12:32 PM Reply With Quote
Well after a long time I'm hopefully going to find time to look at this over the winter again.
I'd like to fit wide wishbones to the car, but what about everything else? Did anyone figure out how to fix the bump steer and anti-ackerman?
G
Graham
