*davies144*
posted on 16/7/09 at 06:41 PM |
WTD: trying to blag a small piece of gasket paper 1mm thick
hi i need a small amount of the above about
130x130 mm? cheers ben
austin man
posted on 16/7/09 at 08:21 PM |
use a cereal box used many over the years none ever failed, alternatively can you just use silicone ??
posted on 16/7/09 at 09:18 PM |
Or hylamar blue?
ReMan
posted on 16/7/09 at 10:11 PM |
All Bran gives the best seal!
Seriously cereal or other, thicker cardboard boxes, greased make good gaskets
MikeR
posted on 16/7/09 at 10:13 PM |
I used a pizza box for a while .... obviously the brand makes a large difference. I'll give you a clue, mine was a green box.
posted on 16/7/09 at 10:14 PM |
Within what time span ? Cardboard rots when exposed to water, I made a thermostat gasket and it was non existent after 2 months. I bought an A4 sheet
to replace it but it wasn't 1mm thick. You could use a few layers of thinner stuff.
UncleFista
posted on 17/7/09 at 01:28 AM |
I bought
this on eBay last month, quick
delivery and quality gasket material.
I've used most of it, otherwise I'd have sent you some, but I can vouch for the seller
Tony Bond / UncleFista
mad4x4
posted on 17/7/09 at 07:34 AM |
My local motor factors has gasket paper.
Scot's do it better in Kilts.
*davies144*
posted on 18/7/09 at 11:46 AM |
geat ideas! thanks for all the help i wil try it today ! ben
