cd.thomson
| posted on 19/7/09 at 06:32 PM |
Completely fed up with it
anybody fancy swapping their completed kit for an incomplete one before I take it down the tip
Craig
Dangle_kt
| posted on 19/7/09 at 06:38 PM |
I've just been on pistonheads thinking the same thing. Getting royaly cheesed off with redoing jobs! I've delayed my sva 4 times now and I
think I may have to again! I've only got just over 2 months till I loose the sva and have to get an iva. I keep telling myself it will be worth
it when it's done...
Chin up. Your not alone.
big_wasa
| posted on 19/7/09 at 06:46 PM |
You want to try a locost from scratch.
Hammerhead
| posted on 19/7/09 at 06:53 PM |
what problems are you having?
Mark Allanson
| posted on 19/7/09 at 06:56 PM |
You need to take a week off from it and get someone locally to take you out for a howl. Batteries recharged, morale high and rearing to go
Ninehigh
| posted on 19/7/09 at 07:17 PM |
If you're going to take it to the tip I'll have it! I'll even collect if it'll fit in the back of me mondeo!!
Don't give up, try saving up for a welder and then having something break on the house and watch welder money go cos you need hot water more..
blakep82
| posted on 19/7/09 at 08:20 PM |
nooo don't do it!
________________________
cd.thomson
| posted on 19/7/09 at 08:26 PM |
every single job, no matter how small or large, requires inordinate amounts of hassle to resolve.
the current example is fitting my engine:
after having two extra sets of fabricated engine mounts because the originals didnt fit and the replacements didnt either I come to fit the engine
after its all sorted and the starter fouls on the chassis.
Options include: replace chassis tube? fine apart from the fact I know nothing about chassis design and I can't weld, there is also noone nearby
who can weld even for money. Or a replacement starter for an XE engine, which I don't know if they exist, dont know if a replacement would even
fit and can't afford anyway.
This is just one example, without going into the clutch pedal which tries to catapult you out of the car when it was trialed (when the engine was in
without the starter), the brake pipes I've had to replace and alternator that mounts to the inlet manifold thats no longer fitted.
Craig
oldtimer
| posted on 19/7/09 at 08:33 PM |
Us scratch builders say, So? Keep going, chin up, if it was easy it wouldn't feel the same.
eccsmk
| posted on 19/7/09 at 08:36 PM |
unfortunately we all go through times where we feel the need to give up,
after a decent pint and a decent sleep you will see that not everything is against you and looking forward to when it done
you will realise all the struggling
and lack of money was all worth it because
you will own a car that you put together and is just such brilliant fun
so keep at it mate it WILL come right in the end trust me
cd.thomson
| posted on 19/7/09 at 08:38 PM |
I'd have scratch built the car if I'd have wanted to scratch build it.
A "scratch builder" has amassed a collection of skills right from the start of the project to overcome these issues which I have not. A
small welding job for you, is a virtual impossibility to me.
Craig
Mark G
| posted on 19/7/09 at 08:48 PM |
You're right though. It will all be worth it.
I hit problems when building mine too and sometimes it feels that you make no progress even after a few months of evening and weekends.
Trust me, When its all finished and you're driving down the road just listening to the sweet hum of the engine its all worth while!
niceperson709
| posted on 19/7/09 at 10:38 PM |
How badly is the starter fouling the frame ?
You may find that if you just a bit of judicious hammering may solve the problem by denting the tube enough for clearance.
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
| posted on 19/7/09 at 11:04 PM |
Whereabouts in Notts are you ? How bad is the starter fouling and could you cut the rail to miss it and get to it to weld a piece in ?
Ninehigh
| posted on 19/7/09 at 11:39 PM |
Get one of these nippon ones everyone goes on about, they're supposed to be really small
LBMEFM
| posted on 20/7/09 at 05:48 AM |
There is not one of us that hasn't felt like you during the build, but as they say you WILL get there in the end. Good Luck Barry.
speedyxjs
| posted on 20/7/09 at 06:10 AM |
Im at that point at the moment. Just saved up enough for megasquirt and the rear shocks go on the tintop which i need to get sorted before august
oldtimer
| posted on 20/7/09 at 07:02 AM |
I wasn't being funny with you and I'm sorry if my reply sounded unstmpathetic. I'm not. It is just that we've all been there
and practically all issues are solvable. We all get to block points when a completely unforseen problem stops us. You WILL solve it and you'll
feel better when you have. I have been stumped so many times on my build some days I could have pushed it onto the street for takers. It happened to
me endlessly on my first build and now I'm doing it all again....
There is no truer saying than - things are never as bad as you immagine them to be.
You are getting there and you have all of us behind you too.
Best of luck.
Martin
jabbahutt
| posted on 20/7/09 at 07:25 AM |
Sorry for being stupid bit did you order the chassis from Dax or buy it from someone who had to give up on the project? Reason I'm asking is if
you ordered the chassis wouldn't Dax of asked what engine you were fitting? I'm suprised that a standard starter is fouling unless
it's a different type of engine than the chassis was built for.
If you ordered direct from Dax have you rung them to speak about the problmes you're having as they may be able to suggest a solution.
cd.thomson
| posted on 20/7/09 at 08:17 AM |
It's an ex-pinto project but I am fitting the XE on the explicit information from Dax that the chassis is exactly the same and the alterations
required are to the rear water port and new engine mounts.
I've had a sleep and I'm less angry at it, but still at a loss really. Please see the attached picture to see an extremely bad
representation of the issue. I'm guessing I cant just cut that tube out - it must be there for some important reason.
the part that actually hits the rail isnt the starter, its the little tacked on bit (solenoid?) so a starter with a separate solenoid would work! if
they existed
[Edited on 20/7/09 by cd.thomson]
Craig
mcerd1
| posted on 20/7/09 at 08:22 AM |
.....wouldn't Dax of asked what engine you were fitting? I'm suprised that a standard starter is fouling unless it's a different
Craig, if I remember right yours is a pinto / DeDion chassis (same as mine) and dax told me that the only difference if I wanted to fit a red top was
the engine mounts (but I think they use the 7deg. bellhousing)
what kind of starter are you using at the moment and how much space do you need ?
[edit: too slow again.....]
[Edited on 20/7/09 by mcerd1]
cd.thomson
| posted on 20/7/09 at 08:27 AM |
oh they roll it over slightly! that makes sense, although not sure that would completely solve the issue.
I need about 2cm
Craig
mcerd1
| posted on 20/7/09 at 08:29 AM |
its more money than you want to spend, but have you looked at high torque starters ?
they are much smaller than the ford ones (so I assume they are smaller than vauxhall ones)
I got one for my pinto from H&H ignition, they are really helpful (and allot cheaper than burtons / demon thieves etc.)
linky
also there are a couple of folk on the other forum that have put a vauxhall engine in a pinto chassis (not sure what bellhousing they used though)
oh and give Gary or Peter @ Dax a call they might have some suggestions
cd.thomson
| posted on 20/7/09 at 08:54 AM |
the high torque starters are the same shape unfortunately
also im fairly sure gary and peter will be unimpressed with me. I've phoned the before and the implication has always been - if you're not
building it as laid out exactly as shown in the manual then dont come moaning to us..
Craig
mcerd1
| posted on 20/7/09 at 09:14 AM |
they can be allot smaller though
