New Topic New Reply
Author: Subject: Think MK have made a mistake on my chassis
EasyJimbo
posted on 21/7/09 at 01:11 PM Reply With Quote
Guys
think MK have welded my gear link bracket the wrong way round, checked with Mark G who is local to me and his is the other side?
Are others the same, as mine is very much over to the right hand side as you look at it straight on from the drivers perspective. Pic attached.
http://www.flickr.com/photos/jes100/3742034691/
thanks
James
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
jack_t
posted on 21/7/09 at 01:19 PM Reply With Quote
hi james did u buy the gear change kit from them?
i noticed in one of your other pictures that there maybe a hole drilled in your drivers side centre console upper rail...is this so
regards jack
EasyJimbo
posted on 21/7/09 at 01:21 PM Reply With Quote
Hi
No I didnt but the gear change kit, just the deluxe kit as a starter.
thanks
james
Miks15
posted on 21/7/09 at 01:28 PM Reply With Quote
why dont u speak to MK? Surely they can give you an answer
jack_t
posted on 21/7/09 at 01:29 PM Reply With Quote
it looks like they have put they provisions in for one of their gear change kits ive seen 2 versions they do
1 where the lever is bolted in the centre of the console
2 where the lever is bolted on to a tubular bracket the
mounts where your bracket is then further down that rail where it looks like there is a hole
unfortunately i dont have a picture of the 2nd one but ive seen it on the red busa car they have at the factory
regards jack
EasyJimbo
posted on 21/7/09 at 01:32 PM Reply With Quote
I have emailed them several pictures and followed up with a phone call and that was a week ago, I will try chasing them again. I just wanted to see what others had setup on there chassis's
thanks
J
Garage Clearout
posted on 21/7/09 at 01:40 PM Reply With Quote
Looks ok to me, not sure what you think's wrong but if your talking about the bracket mounted in the centre console, then that's as they normally are from what i've seen.
EasyJimbo
posted on 21/7/09 at 01:43 PM Reply With Quote
My major concnern was that On Mark G chassis his bracket was mounted on the other side (so left as you look at it), where as mine is on the right hand side.
J
PAUL FISHER
posted on 21/7/09 at 02:03 PM Reply With Quote
Its not a problem,it does not matter if its to left or to the right,Ive seen them fitted both sides,when you fabricate your gear lever,just put a bend in it to the left,so its in the centre of the transmission tunnel
welderman
posted on 21/7/09 at 02:15 PM Reply With Quote
when i make my gear change i put it in the middle, would have been better on one side or the other, if that helps
Joe
Thank's, Joe
I don't stalk people
EasyJimbo
posted on 21/7/09 at 02:17 PM Reply With Quote
Thanks for the replies guys, you have put my mind at rest.
speedyxjs
posted on 21/7/09 at 02:46 PM Reply With Quote
That car is too tidy
MK chippy
posted on 21/7/09 at 06:17 PM Reply With Quote
too right it is!! I remember the days when mine looked like that!
Dave
EasyJimbo
posted on 21/7/09 at 06:49 PM Reply With Quote
thanks guys, i like to be tidy, although I doubt it will last long.
J
New Topic New Reply
