Poll: De-dion? [View Results]
Fit the De-dion I've cobbled together.
Make the De-dion to a tried and tested design (Rortys).
Start again and go full IRS.
Leave the Atlas in there and put up with the horrific wheelspin and popping diffs.
<<  1    2  >>
Author: Subject: De-dion?
owelly
posted on 22/7/09 at 09:30 PM Reply With Quote
De-dion?
The rear end of my Magenta LSR is crap. It's currently running a standard Capri Atlas on trailing arms with a Panhard rod.
I've bought a Sierra LSD and cobbled together a De-dion. I've just spotted Rortys design and mine doesn't look too wrong but what do you folks think??
And the reason for using the Diahatsu calipers......
To fit inside a 13" wheel.
I havn't welded the trailing arm brackets on yet as I intend using the brackets on the forward (car body) end to fix the subframe to hang the diff off as there is no steel work rear of them!! I'll then move the trailing arms out a bit.
http://www.ppcmag.co.uk
M$RK_VXRD
posted on 22/7/09 at 09:39 PM Reply With Quote
i voted to fit urs!
but wouldnt it be better to just use one piece of bar with a bend in it rather than 3 welded together?
owelly
posted on 22/7/09 at 09:45 PM Reply With Quote
The only thin walled tube I had was 3" and I couldn't bend it!
M$RK_VXRD
posted on 22/7/09 at 10:06 PM Reply With Quote
couldn you get a local engineering firm to bend it for you i cant see it costing much?
owelly
posted on 22/7/09 at 10:09 PM Reply With Quote
Costing much?? Have you seen the car?? A fiver would be more than it's worth!!
Did I mention I'm a tight arsed Yorkshireman?!
M$RK_VXRD
posted on 22/7/09 at 10:19 PM Reply With Quote
lol so am i but if u went on a weekend to an engeering company when gaffers arnt in im sure a lad would do it you 4 £5 or £10 max
Lars
posted on 22/7/09 at 11:17 PM Reply With Quote
i have just finished mine and it looks remarkably simar to yours.
I also have it in 3 sections. Almost looks like a copy.
should be strong enough.
I have used a small shim on one side to align it just right.
Volvorsport
posted on 23/7/09 at 10:43 AM Reply With Quote
i thought the aim was to save unsprung weight ?
could have cut a 340 one up, there about a fiver from the scrappys .
www.dbsmotorsport.co.uk
getting dirty under a bus
craig1410
posted on 23/7/09 at 11:49 AM Reply With Quote
That looks fine, I'd just go with it although I'd be tempted to grind down the joints between the centre of the axle tube and the two angled pieces and weld over the existing joint with some 3mm plate to act as load spreaders. Just takes a bit of the reliance away from the single welded joints.
The only other thing you might have difficulty with is fitting a panhard rod because of the angle it would have to run at longitudinally to get around the longitudinal depth of your axle. Easy solution would be to build a watts linkage instead which is technically better than a panhard rod anyway. If you do decide to use a panhard rod then remember it needs to be as long as possible and should be parallel to the ground at ride height.
Watts linkage in Wikipedia:
http://en.wikipedia.org/wiki/Watt's_linkage
Good luck!
Craig.
[Edited on 23/7/2009 by craig1410]
owelly
posted on 24/7/09 at 12:57 PM Reply With Quote
Cheers folks. I'll go with the majority and fit the thing I've made!
I was intending to fit a Watts linkage and I've already welded a plate to the back of the tube to fit it. The welds that are on there are far stronger than the rest of the car so I'm happy that they'll outlast the car!!
The set-up is light enough to lift with one hand and that's including the brakes and discs. The diff will add more weight but I'm sure the whole lot will weigh less than the Volvo axle. If I'd had a Volvo axle in my shed, I would have fitted that as I'm prone to use whatever I have close to hand!!
Cheers folks!
owelly
posted on 29/3/12 at 10:54 PM Reply With Quote
Just a quick update as I've had a few minutes here and there...
De-dion and subframe made to locate on existing trailing arm mounts, fitted with diff, shafts, brakes etc, and the coilovers balanced on top to get an idea of the weight...
It comes in at 105kg. I can lose a bit more weight by making a lighter Watts pivot and using thinner walled tube for the subframe, but I used whatever I had kicking about the garage.
The Atlas I took out weighs 80kg, including drums, coilovers, backplates, etc. So a 25kg increase in weight, but a lot less unsprung weight, disc brakes and an LSD.
owelly
posted on 29/3/12 at 11:14 PM Reply With Quote
And yes, it has only taken me three years to get around to finishing this.....
mcerd1
posted on 30/3/12 at 07:27 AM Reply With Quote
that looks quite neat
DIY Si
posted on 30/3/12 at 03:25 PM Reply With Quote
That's about what I reckon mine will end up weighing, although mine is a narrowed Caterham version, so has a straight tube. The only difference is that mine is in a Sprite will extend the tunnel to mount the diff.
Rather than using a panhard rod, would it be any better to use the trailing arms angled outwards to provide lateral location? It would mean making new ones though, and I'm not 100% sure if you'd have space at the outer edges of the tube to mount them.
Sun Tzu, The Art of War
owelly
posted on 30/3/12 at 05:22 PM Reply With Quote
The problem with triangulating the set-up using the trailing arms is that the beam becomes over-located. When cornering, the axle would be in a twisting force. It wouldn't be a problem if there was a sliding joint in the de-dion.....
posted on 30/3/12 at 05:47 PM Reply With Quote
Unless you only turn one of the trailing arms into a "wishbone", in which case there will be no binding. It's something I thought about ages ago, but I've never seen it done so I presume there must be a disadvantage.
That's a hefty looking axle BTW, I doubt you'll be suffering from GTS syndrome (snapping in half at the welded section of the tube) and it should at least be very rigid.
[Edited on 30/3/12 by MikeRJ]
owelly
posted on 30/3/12 at 06:05 PM Reply With Quote
I did think of making a single centre mounted A-frame type thing to mount of the subframe to the de-dion but that may be for a future developement...
DIY Si
posted on 31/3/12 at 08:50 AM Reply With Quote
That's exactly how mine works, being a Caterham set up. In my case, the lower A arm is parallel at what should be ride height, so despite sticking down a fair bit, it's still level with the sills.
How heavy is your main tube? I can pick mine up with just my little finger, but I've obviously got all the diff, shafts and hubs to add as yet and they're most of the weight.
owelly
posted on 31/3/12 at 07:41 PM Reply With Quote
My plain tube with flanges and brackets, but no hubs, brakes, arms etc weighs about 6kg. Its very light!
froggy
posted on 31/3/12 at 08:21 PM Reply With Quote
I preferred it going up the 1/4 in a clown car stylee myself
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
owelly
posted on 1/4/12 at 07:23 PM Reply With Quote
It's strange you should say that Froggy, I dissapponted a few folks by not taking the Tupperware Turd to Santa Pod yesterday. They all wanted to see my crap car jumping up the strip....
froggy
posted on 2/4/12 at 08:39 PM Reply With Quote
What you really need is a clown wig and red nose for Mallory park next month .
Nickp
posted on 3/4/12 at 05:49 AM Reply With Quote
How rude!!
I think there might be less laughing this year and there may even be a shock on the cards at Santa Pod If he can get the thing to actually steer!!
TAZZMAXX
posted on 3/4/12 at 06:20 AM Reply With Quote
Maybe this isn't the right place to ask but what actually is the advantage of a De Dion axle over full Sierra IRS? To me, it looks like it adds weight unnecessarily or is it just an easier way of going from a rigid axle without fitting wishbones?
Thanks.
owelly
posted on 3/4/12 at 06:32 AM Reply With Quote
Discussed here: http://www.locostbuilders.co.uk/viewthread.php?tid=14769
I was on my way to buy steel to convert my car to IRS when I found an old steel lamp post at the side of the road, so I used it to make the De-dion tube. That is why I chose De-dion......
<<  1    2  >>
