Author: Subject: Engine sprocket to prop flange
Frosty
posted on 30/7/09 at 12:35 PM Reply With Quote
I have a friend doing a BEC conversion on a car and he asked where I got my prop flange adapter for my Busa. This is the component that replaces the chain sprocket on the standard engine.
Mine came from Westfield so was sourced for me. He needs one splined to suit a GSXR1000 and ideally undrilled.
Does anyone know where they are available from?
matt_gsxr
posted on 30/7/09 at 12:47 PM Reply With Quote
something like a sprocket adaptor?
Try http://www.sprocket-adaptors.co.uk/
Matt
irvined
posted on 30/7/09 at 02:10 PM Reply With Quote
Second for Sprocket-adaptors.
http://irvined.blogspot.com
Frosty
posted on 30/7/09 at 02:23 PM Reply With Quote
Cheers guys
tommyab
posted on 30/7/09 at 02:49 PM Reply With Quote
Slightly different but I was trying to fit mine today - cant get the old sprocket off though as cant undo the nut. Any suggestions? 05 R1 engine.
sucksqueezebangblow
posted on 30/7/09 at 04:37 PM Reply With Quote
You need to jam the sproket so it doesn't turn. Check your manual to see how to do it.
Frosty
posted on 30/7/09 at 04:38 PM Reply With Quote
Yes use an impact wrench with the engine in gear, other wise you just end up spinning the sprocket freely.
MK chippy
posted on 30/7/09 at 04:46 PM Reply With Quote
Seconded^^^^^^^
Done this on mine and it was off in seconds.
Dave
tommyab
posted on 30/7/09 at 06:31 PM Reply With Quote
Many thanks gents. After a couple of hours struggling with it earlier tried your suggestion and was undone in about 10 seconds !
