Author: Subject: refinishing brushed stainless steel
markyb
posted on 1/9/09 at 05:36 PM Reply With Quote
Because of Mr SVA I had to glue some rubber trim onto my brushed SS steel exhaust cutout - after the trim 'fell off' some of the glue and rubber had melted onto the surround.
I ended up using Mr dremmel to remove the excess but have scored the surround in the process and was wondering what methods/tools I should use to try and restore the surround to the same brushed effect of the rest of the surround
I dont mind a bit of effort to get it back to looking well but the cutout only cost me approx £30 so no biggie if I need a new one.
SeaBass
posted on 1/9/09 at 05:55 PM Reply With Quote
I use scotchbrite pads on my SS exhaust can when I clean the seven. You get a nice brushed effect but perhaps you've scored the trim so need to use silicon carbide paper first.
JC
cryoman1965
posted on 1/9/09 at 05:58 PM Reply With Quote
Scotchbrite pads. Scrub the SS in the same direction. This will give it pretty much the same finish.
N
Andybarbet
posted on 1/9/09 at 09:27 PM Reply With Quote
Spray the pad with WD40 aswell, we do this with our brushed stainless instruments at work if we scratch them, comes up spot on !
markyb
posted on 1/9/09 at 10:39 PM Reply With Quote
thanks for the info - will pick up some scotchbrite tomorrow and see how I go
