Gergely
| posted on 10/9/09 at 04:38 PM |
What mods are required to take a 5JJ R1 car on track safely?
Hi, I am after some help for a friend who has a 5JJ R1 engined Indy. Since I have a 5VY engined MNR and I had to have modifications to it, I want to
help him avoid a costly mistake...
He has a sump baffle plate, but other than that, uses everything as standard, even the airbox is the same as on the bike, the radiator, fans are from
the bike, too and the cooling pipes are all routed as on the bike originally.
Would he be able to take the car safely to the track? Or are there any other modifications required (AIS breathers, oil catch tank, exhaust port
modifications, etc...)? How much oil should he have? Overfilled slightly?
Can anyone with a 5JJ engine who races or goes on track confirm, please?
He is on the road for more than a year now, so the car is reliable. (And he doesn't speak too well English, hence me asking it here...)
Thanks!
Gergely
Our build pictures
progers
| posted on 10/9/09 at 07:40 PM |
Hi Gergely,
I raced a 5PW engined Phoenix for several years and also tracked a 5JJ car (MK Indy) before that. The engines are almost identical apart from the
fueling system.
Basically the engine works well with just a baffle plate and slight overfill of oil (its much simpler/reliable than your engine in that respect). For
oil level, get the engine warm, at tickover the oil should be somewhere between the middle and the max fill mark of the sight glass.
Other than that he shouldn't have any major problems. I used the R1 radiator and it works well if it has air properly ducted to it. The only mod
I made to my race car was to have a small oil cooler as well - not strictly needed for a trackday car.
Hope that helps
Paul
StevieB
| posted on 10/9/09 at 09:12 PM |
Baffle plate is pretty much it - I'd recommend a jet and needle kit and foam filter from TTS for a little more grunt but thats about as much as
it needs.
As said, a slight overfill on the oil (I keep mine at the top of the sight glass when warm at tickover) and keep a regular eye on the oil level as
R1's like to get through a bit quicker than some.
Coose
| posted on 11/9/09 at 07:23 AM |
As Steve says, keep an eye on the oil and keep the level at the top of the sight glass at tickover. It WILL burn oil but don't worry about it,
just enjoy!
Spin 'er off Well...
Gergely
| posted on 11/9/09 at 09:13 AM |
Thanks guys! I explained to him all what you suggested, so hopefully he will join me on the track soon!
Gergely
Our build pictures
