tegwin
| posted on 14/9/09 at 09:27 AM |
Engine rebuilding-overbore
I want to play with an engine, as a learning tool and for a bit of fun.
I am looking into buying the same engine that I have in my polo and have a "play" with it.
its a 1.6 16V VVT Steel crankcase alloy head engine (standard its 125hp and 130nm)
What I was thinking was, strip it down and rebuild from the ground up with the possibility of adding a bit more bite to it without damaging
reliability too much.
I was thinking about getting the block overbored to increase capacity, but how do you work out how much is possible without compromising the block?
And assuming you have managed to overbore the block, where do you buy suitably sized pistons for such an obscure engine?
Can a reasonable power increase be gained from higher capacity like this?
As well as the above I was contemplating fiddling with the head and fitting larger valves and intereting cams...
[Edited on 14/9/09 by tegwin]
www.verticalhorizonsmedia.tv
| posted on 14/9/09 at 09:38 AM |
Buron Power - they can supply pistons made to your spec. - not locost
How much is reasonable and how much more capacity? Put it this way, the bhp of most production engines is around 75 % of the capcity i.e.
120 bhp for 1,600 cc ; if you get 100% then that is really good going i.e. 160 bhp from 1600 cc.
tegwin
| posted on 14/9/09 at 09:41 AM |
Do you think its possible to get nearer 100% from an engine, but still keeping it normally aspirated?
l0rd
| posted on 14/9/09 at 09:47 AM |
yes look at civic VTec
| posted on 14/9/09 at 09:49 AM |
sorry but I am no expert but we do see figures aproaching 100% for certain engines;
e.g. Raw engineering getting 180 bhp from 1.6 16 valve 4age engine;
ISTR seeing 225 bhp from vauxhall red top
also 185 bhp from 1700 crossflow?
all normally aspirated but at eye watering prices plus only useable on the race track.
l0rd
| posted on 14/9/09 at 09:50 AM |
I know someone that had a Renault 19 RSi. Same engine with my ex clio.
He turbocharged the engine and used pistons and conrods from the 1.9 diesel renault engine.
I assume as diesels run on high compression ratios they can be used on petrol turbocharged engines
sickbag
| posted on 14/9/09 at 09:54 AM |
It's easy to attain if you just increase the rev limit - 1000cc R1 motor makes about 160BHP, but at 11,000RPM. The torque figure is around
84Ft/Lbs though.
So, if you want more BHP then just raise the rev limit, if you want more torque then tune the rev range you have.
Finally back on the job!
blakep82
red tops can get near 300bhp. sbd have kits for 292bhp for a N/A engine
click
230~bhp is possible from a red top with standard internals i think
[Edited on 14/9/09 by blakep82]
________________________
| posted on 14/9/09 at 11:31 AM |
Diesel pistons are in general completely unsuitable for high performance petrol engines. They tend to be very heavy, have very thick rings and most
have the combustion chamber built into the crown.
| posted on 14/9/09 at 12:34 PM |
I am puzzled by this too ...... Diesel use high CR to heat up the air so much that the injected fuel commusts;
Petrol turbo enignes use air that has already been compressed so to avoid detonation (?) the CR of the engine is reduced. That is why you can buy
decompression plates as a cheaper alternative to lower CR pistons.
Can't see how you can use a rod and piston from high CR piston to work in a low CR turbo engine.
Canada EH!
| posted on 14/9/09 at 01:58 PM |
Check the manual and suppliers of pistons, they will tell you how far you can go, 60 thou is usually about tops for small 4 cylinder units. Larger
pistons will also increase the compression ratio, which adds performance.
Coose
| posted on 14/9/09 at 02:16 PM |
It depends on the motor. I've just taken out my '72 Yamaha XS-2 (653cc parallel twin) by 3mm (100 thou) taking it to 707cc, though the
stock liners won't take much more. But, with new liners in the stock block I could go to 860cc, with a new block I can go to 990....
Spin 'er off Well...
| posted on 14/9/09 at 04:39 PM |
I think l0rd was possibly referring to the fact that diesel pistons are designed to cope with very high combustion pressures which you find in
turbocharged petrol engines.
