Author: Subject: BEC engine mouting soft or hard?
franky
posted on 15/9/09 at 09:11 PM Reply With Quote
As above, been having a 'discussion' with a friend over the merits of the above....
I'm undecided, he reckons a solidly mounted motor.
What would be the best type of anti-vibration mounts suitable or engine type mounts for a BEC?
Dangle_kt
posted on 15/9/09 at 09:17 PM Reply With Quote
solid.
I may be wrong but I havn't seen any soft mounted bike engines. Not even in bikes - (thats right I don't class Harleys as bikes!)
designer
posted on 15/9/09 at 09:27 PM Reply With Quote
Why not use metalastic bushes, fairly solid and might take out a few vibrations?
adithorp
posted on 15/9/09 at 10:05 PM Reply With Quote
Mines mounted on metalastic bushes.
adrian
http://jpsc.org.uk/forum/
ReMan
posted on 15/9/09 at 10:09 PM Reply With Quote
I like the idea of a slightly more compliant mounting just to lose a bit of harshness, but, I think you'd have to be very careful not to stress the engine mounts outside of their design?
mark chandler
posted on 15/9/09 at 10:55 PM Reply With Quote
poly bushes for me, used landrover panard bushes, you can turn these down for a perfect fit, nice and cheap.
sickbag
posted on 15/9/09 at 11:02 PM Reply With Quote
I would have thought it was personal preference, but do remember that most of the motors used in BECs were designed to be rigidly mounted in the bike chassis they came from, and actually formed most of the bikes chassis rigidity.
Finally back on the job!
nitram38
posted on 15/9/09 at 11:10 PM Reply With Quote
MotaLeira R1 solidly bolted into the chassis. No issues with vibration.
More important if you have a chain drive. The last thing you want is a slack chain as the motor moves about!
tomblyth
posted on 16/9/09 at 07:38 AM Reply With Quote
mines on Car engine rubber mounts at the front and metal elastic bushes at the back!
motorcycle_mayhem
posted on 16/9/09 at 08:36 AM Reply With Quote
Mine's on metalastic bushes, pretty firm ones. Why? Dunno, it's how I did it at the time. Result has been brilliant.
NB, I have a propshaft set-up. If you're doing a (more) sensible mid-engine/chain combo, you need to rigidly mount everything.
As an aside, the Sprint R, mid-engine/chain, uses(d) a fairly sloppy rubber frame mounting by comparison, but the diff/chain was part of the frame with the engine. Probably a good set-up if middle age prostate hang-ups mean you can't sit in a vibration without wanting to go all the time.... don't ask.
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 16/9/09 at 08:45 AM Reply With Quote
My Indy was solid mounted with no issues at all
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
PAUL FISHER
posted on 16/9/09 at 09:56 AM Reply With Quote
The 1st run of early Sprint R's had rubber mounts,they had problems with too much movement in the engine,all sprint R 's since have been solid mounted.
My vote would be for solid mount as in the bike,Ive not noticed a problem with vibration on any BEC's Ive drove and owned over the years,and lets face it you don't drive a BEC for the ultimate in refinement.
Gav
posted on 16/9/09 at 09:57 AM Reply With Quote
My blade engine has bolts through the top mounts to a plate which swivels in bush on the cradles main frame.
The bottom mounting had poly bushes.
Pic 1
Pic 2
Mr Whippy
posted on 16/9/09 at 11:06 AM Reply With Quote
why not fit the metalastic mounts to the seat instead? especially if it a GRP one. You could easily do the same to the column to isolate you hands from vibrations.
SPYDER
posted on 16/9/09 at 03:26 PM Reply With Quote
Metalastik bushes on our Phoenix. The diff is poly bushed.
Geoff.
lsdweb
posted on 16/9/09 at 04:49 PM Reply With Quote
What would Colin Chapman do?!
Solid mount for stiffness. Probably make it a stressed member of the chassis / car and then remove some of the other unnecessary chassis members... :-)
