mangogrooveworkshop
| posted on 6/10/09 at 09:43 PM |
Which wire does what on Lucas wiper motor
Ive decided that I better wire up the wipers on my car ......that have been on it for ages..
Its Lucas to premier wiring loom.......
Theres 3 wires inc park? Yellow red and blue
need terminals numbers and colour diagram.
Thanks persons of the netland
owelly
| posted on 6/10/09 at 09:48 PM |
Any good?
http://www.ppcmag.co.uk
mangogrooveworkshop
| posted on 6/10/09 at 09:50 PM |
ta that will do
Dusty
| posted on 6/10/09 at 10:17 PM |
Blue (earth.1), red (fast.3) and yellow (slow.5) are wires from the motor brushes to the park switch which you need for self parking.
mangogrooveworkshop
| posted on 6/10/09 at 10:23 PM |
thanks
RK
| posted on 6/10/09 at 11:37 PM |
On mine, the park doesn't work, so I used the extra switch I had it wired to (in addition to the off, slow and fast switch) changed into a
reverse light switch.
| posted on 7/10/09 at 07:39 PM |
Are you using a Lucas wiper motor similar to the one in Dusty's photo? If so parking problem is likely to be either the parking switch or
possibly excessive end float in the drive gear shaft. Just take off the circlip on the end of the shaft and shim the play out , it may cure the
problem. IIRC The Robin Hood owners site has a diagram showing what wire does what, might be worth a look
RK
| posted on 7/10/09 at 11:41 PM |
Thanks Rusty, but the inspector here doesn't care if it parks by itself or not, so I'm going to do something I don't usually do:
ignore the issue and hope I never think about it again! The wiper is the absolute least of my build problems at the mo. I'm very very close to
finished.
