Mave
posted on 10/10/09 at 08:44 AM |
possible Zetec exhaust manifold?
Would it be possible to adapt this Zetec manifold for use in a Seven? I was thinking of cutting it at the 4 -into-2 point, shortening the lower
section and of course turning it around so it points out of the engine bay. My main concern is however that the 4-into-2 point is already too low, so
I won't have room to bend the tubes outboard. It's hard to tell from the pictures, and it's a bit too expensive to just buy it and
measure it up.
I really like the shape though....
Ebay LINK
[Edited on 10/10/09 by Mave]
theconrodkid
posted on 10/10/09 at 08:57 AM |
tried that once,ended up in the bin
best to get a proper one from raldes or ashley manifolds
[Edited on 10/10/09 by theconrodkid]
who cares who wins
pass the pork pies
tomgregory2000
posted on 10/10/09 at 09:01 AM |
i did it with a standard tubular vauxhall red top manifold and was fine, it fitted the car but not great for top end power as its too small diameter
austin man
posted on 10/10/09 at 09:15 AM |
lot of work you could end up wasting nearly £200 notes. I think GBS will seel u one in component form. Tiger do tham along with many other
manufacturers
big_wasa
posted on 10/10/09 at 12:50 PM |
Put a few more quid to it and get a westfield one or for that money as said Tiger, GBS, or Fisher if they still do one.
If you want to have a go at cutting one up look for a s/h st170 exhaust.
Mave
posted on 11/10/09 at 08:23 AM |
Hmm, you're all probably right. Standard Westfield/Tiger etc. manifolds won't fit my chassis without modification though. So I'll
have to cut something up and make it work anyhow (unless I want the headers to go over the chassis, like the MK manifold, but I don't really
like that).
