New Topic New Reply
Author: Subject: Brake lines hitting front tyre
Colnago_Man
posted on 11/10/09 at 10:53 AM Reply With Quote
Just noticed, that my flexi brake lines touch the front tyre when on full lock. I've had the caliper off this morning and trying to find away of curling the line the loopy bit stays between the wheel and body of the car.
The solution that worked the best was a complete loop in the middle of the flex line but this gets pulled quite tight on full lock.
What has anyone else done?
gregs
posted on 11/10/09 at 10:57 AM Reply With Quote
Mine are quite long but controlled by being clipped to my cycle wing supports. Without this they would touch the tyre.
Might help with a pic.
turbodisplay
posted on 11/10/09 at 11:35 AM Reply With Quote
I welded a steel tube to the upper mount of the upright. Passed flexi throught this hole.
This keeps it in check, yet didi not reduce availible movement.
Darren
M$RK_VXRD
posted on 11/10/09 at 12:24 PM Reply With Quote
were does the fexi exit the bodywork as mine worked better being below the calliper rather than above check my pics! any pics of yours may be easier for us to sugest a solution!
New Topic New Reply
