tomgregory2000
posted on 11/10/09 at 07:59 PM |
The start of my winter project, engine change from c20xe to......
So in the quest for more horse power than one of these could give me for resonable money and keep drivability
![](/galpreviews/Engine for sale.jpg) ![engine fs](/gallery/Engine for sale.jpg) engine fs
i am now the proud owner of one of these all alloy engine's
![](/galpreviews/cam cover.jpg) ![Description](/gallery/cam cover.jpg) Description
Can you tell what it is yet?
Here are a few more pics for you.
![](/galpreviews/front of engine.jpg) ![Description](/gallery/front of engine.jpg) Description
![](/galpreviews/turbo and manifold.jpg) ![Description](/gallery/turbo and manifold.jpg) Description
TURBO POWER!!!!!!!!!!!
![](/galpreviews/2turbo.jpg) ![Description](/gallery/2turbo.jpg) Description
![](/galpreviews/7flywheel.jpg) ![Description](/gallery/7flywheel.jpg) Description
Rather super lightweight racing flywheel and rigid paddle clutch
![](/galpreviews/6clutch.jpg) ![Description](/gallery/6clutch.jpg) Description
And a nice all alloy gearbox
![](/galpreviews/7gearbox.jpg) ![Description](/gallery/7gearbox.jpg) Description
This engine (known as an sr20det) is normally found in a nissan 200sx, and this engine is putting out 321bhp the only mods needed to reach this
level of horsepower is bigger injectors(running 760cc), the stainless manifold, 3" exhaust and upgraded wastegate actuator, the limiting factor
is the standard turbo, but it should make my car shift a bit.
First job is to give it a propper good clean, its mucky.
Will keep this updated as i get on with the change from one good engine to a mental one
Tommy
speedyxjs
posted on 11/10/09 at 08:02 PM |
That is going to go like hell!!!
I look forward to seeing that upgrade progress
posted on 11/10/09 at 08:11 PM |
![](/images//smilies/cool.gif)
Davey D
posted on 11/10/09 at 09:53 PM |
If it is still running the original turbo, then it really is being pushed to its limit. If its running bigger injectors, then it will need some kind
of mapping, either some basic piggyback device like an Apexi Safc, or a replacement Ecu, and it really needs the Maf sensor swapping for a unit from
the Z32 300zx turbo, which will also need some mapping changes, as the standard one is at its limit around that power level. Should be scary quick in
a lightweight kitcar, as my old 200sx really went with 300bhp, and they are 1250kg
blakep82
posted on 11/10/09 at 10:31 PM |
makes me moist
________________________
Davey D
posted on 12/10/09 at 06:15 AM |
Ooh just noticed its got the winged sump on it.
It doesnt say SR20 on the front of it, which normally means it is a cheaper copy. Does it say Greddy on the underside? if not then it is definately
one of the copies. Just keep your eye on it that it doesnt start to go porous, and leak
tomgregory2000
posted on 12/10/09 at 07:15 AM |
All done! running apexi fc with commander and z32 maf and avcr and other bits thats why i bought this one, going to run it till the turbo goes bye bye
and then get a bigger one ![](/images//smilies/bigsmile.gif)
tomgregory2000
posted on 12/10/09 at 07:16 AM |
i prob going to have to replace the sump for a standard one as i think its going to be too wide ![](/images//smilies/sad.gif)
turbodisplay
posted on 12/10/09 at 08:00 AM |
I would think long an hard before usng a solid clutch.
With a lightweight car the chances of trans damage is small, but it could be very harsh making the car horrible to drive.
Darren
posted on 12/10/09 at 01:52 PM |
Agreed, a friend of mine recently fitted a sprung paddle clutch in his civic and he's just ordered a Helix organic plate to fit. Even with the
sprung centre it gives a horribly harsh engagement, especially doing fast changes.
For road I'd use an organic plate every time unless there's no possible way it can handle the power.
Nash
posted on 12/10/09 at 06:00 PM |
That really is a Tim Tooltime Taylor ooohhhrrr!!!
Is it a trick of the picture angle or is that a really tall engine?
Did you pay big money (ballpark if you don't mind me asking)?
Regards..........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
Stuart_B
posted on 12/10/09 at 06:33 PM |
wow, that makes my engine swap look pointless.lol
any way as said i would love to see rough ballpark figuers and prices.
hope to flow this swap as well
stuart
tomgregory2000
posted on 12/10/09 at 07:11 PM |
it is a tall engine, its 3-4 cm taller than the xe im removing but should clear my bonnet,
got to love the room in the vientos
the engine and box and apexi power fc ecu and apexi boost controler and 255L fuel pump and goodridge braided lines and alloy bulkhead fittings other
bits and pieces cost just over 2k which is cheap for 321bhp.
I hope to have it running and in the car for around 2.5 - 3k and by march.
The torque this engine puts out means that a paddle clutch is needed, i may change it for a spring one but it came with the engine so will use it and
see what it is like.
tomgregory2000
posted on 12/10/09 at 09:03 PM |
well i started to take bits off the engine to give it a good clean
![](/galpreviews/parts before cleaning.jpg) ![Description](/gallery/parts before cleaning.jpg) Description
as you can see the oil filter position is not the best in the world as it drips oil down the engine each time you replace it and gets covered in
crap
![](/galpreviews/inlet side before cleaning.jpg) ![Description](/gallery/inlet side before cleaning.jpg) Description
ive done a bit of cleaning on the front and its coming up rather well
the exhaust side is not so bad, just a bit of road grime
![](/galpreviews/exhaust side before cleaning.jpg) ![Description](/gallery/exhaust side before cleaning.jpg) Description
turbodisplay
posted on 16/10/09 at 08:07 AM |
You think that oil filter posistion is bad, a rev1 or 2 3sge/ 3sgte has the filter upside down!
Darren
Werner Van Loock
posted on 16/10/09 at 06:59 PM |
Will be some serious power, but the last SR20DET powered kitcar I've seen ended up like this:
![](/galpreviews/burned_stylus.jpg) ![Jasper's burned Stylus](/gallery/burned_stylus.jpg) Jasper's burned Stylus
So make sure you get everything right, turbo's tend to get very hot you know. (though the turbo was not the cause, fire started other side of the
engine)
http://www.clubstylus.be
tomgregory2000
posted on 21/10/09 at 02:57 PM |
Here are a few update pics.
Got to love an alloy engine, they clean up rather well.
![](/galpreviews/engine after cleaning.jpg) ![Description](/gallery/engine after cleaning.jpg) Description
![](/galpreviews/front after cleaning.jpg) ![Description](/gallery/front after cleaning.jpg) Description
And the removal of the XE engine.
![](/galpreviews/xe engine in car pria to removal.jpg) ![Description](/gallery/xe engine in car pria to removal.jpg) Description
![](/galpreviews/xe engine in car.jpg) ![Description](/gallery/xe engine in car.jpg) Description
![](/galpreviews/xe allmost ready to be removed.jpg) ![Description](/gallery/xe allmost ready to be removed.jpg) Description
![](/galpreviews/xe allmost ready to be removed from rear.jpg) ![Description](/gallery/xe allmost ready to be removed from rear.jpg) Description
![](/galpreviews/sad day as engine is removed.jpg) ![Description](/gallery/sad day as engine is removed.jpg) Description
![](/galpreviews/its just out.jpg) ![Description](/gallery/its just out.jpg) Description
![](/galpreviews/out on the floor.jpg) ![Description](/gallery/out on the floor.jpg) Description
![](/galpreviews/one large empty engine bay.jpg) ![Description](/gallery/one large empty engine bay.jpg) Description
Now the next job on the list is to clean up the bay ![](/images//smilies/smile.gif)
flak monkey
posted on 21/10/09 at 03:18 PM |
Looking good, in a similar position to mine at the moment
Certainly do have to love an all ally engine!
In response to a question you asked the other day, I plan on running 13" rims all round eventually with 195 tyres on the front and 235 on the
back. So 6" fronts rims and 7" rears. But thats another upgrade when money allows.
Sera
http://www.motosera.com
franky
posted on 21/10/09 at 05:14 PM |
Looks like you've cleaned up the engine bay already by removing that antique from it![](/images//smilies/wink.gif)
FlansS14
posted on 25/10/09 at 08:25 PM |
by far the best engine choice
Ive been running mine with basic mods and a H-dev stage one chip and its allot of fun! I thing ill up it to stage 2 over the winter.
thought you might like these pics. i moved some of the diaganal bars arround to clear the manifolds, i also made my tunnel wider but mines a Luego
Velocity chassis.
ive got loads of others if you need them.
oh and PM me a price on the XE setup. A fried of mine is after one
Keep up the good work
Flan
Why didn't i just make it simple!
tomgregory2000
posted on 25/10/09 at 08:39 PM |
WOW thats a tight fit
im glad ive got the viento
just offered up the gearbox over the weekend, its a big bugger and have had to cut a couple bits out of the trans tunnel.
Will get some pics up soon
FlansS14
posted on 30/10/09 at 01:14 PM |
You've got loads of room compared to my tiny bay... should be fine
on and cleaning Aluminuim... Cilit bang for the win!!
tomgregory2000
posted on 5/11/09 at 06:08 PM |
just a little update.
Here is the problem i had with the gearbox
![](/galpreviews/sr20 gearbox nuts.jpg) ![Description](/gallery/sr20 gearbox nuts.jpg) Description
The two nuts that stick out on either side of the gearbox were hitting on the uprights on the trans tunnel and the only job they do is to hold a
spring to center the gearlever
Here is the trans tunnel with a little bit of modification
![](/galpreviews/trans tunnel cut outs.jpg) ![Description](/gallery/trans tunnel cut outs.jpg) Description
and with the begining of the inserts
![](/galpreviews/trans tunnel inserts.jpg) ![Description](/gallery/trans tunnel inserts.jpg) Description
tomgregory2000
posted on 9/11/09 at 05:38 PM |
Well today was the first try of the engine in the engine bay and it fitted!!! (almost)
It looks as though i will be able to keep the sump above the bottom chassis rail and have just enough room under the bonnet
Here are a few pics for you lot
![](/galpreviews/sr20det trial fit 1.jpg) ![Description](/gallery/sr20det trial fit 1.jpg) Description
![](/galpreviews/sr20det trial fit 2 exhaust side.jpg) ![Description](/gallery/sr20det trial fit 2 exhaust side.jpg) Description
I am going to have to move this rail as the exhaust manifold just rubs on it
![](/galpreviews/sr20det clearance issue.jpg) ![Description](/gallery/sr20det clearance issue.jpg) Description
And i think my engine mounts need beefing up a little ![](/images//smilies/bigsmile.gif) ![](/images//smilies/wink.gif) ![](/images//smilies/bigsmile.gif)
![](/galpreviews/sr20det engine mount mock up with toilet rolls.jpg) ![Description](/gallery/sr20det engine mount mock up with toilet rolls.jpg) Description
tomgregory2000
posted on 12/12/09 at 09:09 PM |
Just thought i would post a little update
Here are the new engine mounts
![](/galpreviews/os engine mount.jpg) ![Description](/gallery/os engine mount.jpg) Description
![](/galpreviews/ns engine mount.jpg) ![Description](/gallery/ns engine mount.jpg) Description
I came across a slight problem with the turbo manifold
![](/galpreviews/Turbo clearance issue.jpg) ![Description](/gallery/Turbo clearance issue.jpg) Description
But no more problems
![](/galpreviews/No more clearance issue.jpg) ![Description](/gallery/No more clearance issue.jpg) Description
Just got to glue the tube back in place a little bit further out.
Ive started work on the intercooler and rad brackets, they are getting there but need a bit of finishing off(the intercooler needs to drop down about
5mm) and alot of metal removed as it weighs a ton but here are a few pics
![](/galpreviews/intercooler and rad mounting.jpg) ![Description](/gallery/intercooler and rad mounting.jpg) Description
![](/galpreviews/intercooler and rad from above.jpg) ![Description](/gallery/intercooler and rad from above.jpg) Description
![](/galpreviews/intercooler and rad bit tight.jpg) ![Description](/gallery/intercooler and rad bit tight.jpg) Description
And all being well and dry tomorrow im going to have the engine all bolted in ![](/images//smilies/smile.gif)
