Author: Subject: peugeot electrics
eccsmk
posted on 27/10/09 at 06:02 PM Reply With Quote
peugeot electrics
here's a nice little puzzle for you all to try and help me with
my mother has a 52 plate peugeot 307
with a 6 disc cd player (all cd's stored in head unit)
now the radio will work while ignition is on but the cd will only work when the headlights are on
so technical guys and girls any ideas?
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 27/10/09 at 06:29 PM Reply With Quote
has the car had its 'comm 2000' indicator/ light stalks replaced yet? They were famous for going wonky causing all sorts of wierd electrical maladies!!! A quick google of them will explain........
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
theconrodkid
posted on 27/10/09 at 06:30 PM Reply With Quote
sounds like no power from the fusebox then you get a back feed when the lights are on....i would go for water in the fuse/relay box
who cares who wins
pass the pork pies
jase380
posted on 27/10/09 at 06:49 PM Reply With Quote
as above, sounds like the cd player pulling a live through the lighting circuit..... good look
Ben_Copeland
posted on 27/10/09 at 07:05 PM Reply With Quote
Mmmm more quality electrics from peugeot.
Certainly sounds like its drawing current from the light circuit. Very strange
Ben
Locost Map on Google Maps
Enter Your Details Here
adithorp
posted on 27/10/09 at 07:19 PM Reply With Quote
I've got a customer with the same problem and also the radio sometimes comes on after the key is removed. Trouble is it's intermitent and disapears whenever I try and track it down. Seems to be related to the circuit board for the clock where the radio also displays info' but thats as far as I've got before the symptoms disapear.
adrian
http://jpsc.org.uk/forum/
l0rd
posted on 27/10/09 at 08:03 PM Reply With Quote
If it was a normal cd changer in a normal radio, then there is only power from the head unit.
Being a Peugeot though i do not know. Did you notice yet if the rear 3rd brake light is on all the time and goes off when she applies the brakes?
eccsmk
posted on 29/10/09 at 10:22 PM Reply With Quote
update
it seems there was a fault in the switch (the stalk control for the radio)
and the head unit
ive no idea what these faults were but my electrical genius of a friend sorted it out
thanks locosters looks like you all had the correct idea
