Author: Subject: O/T soffit lights help needed
woodster
posted on 28/10/09 at 08:42 PM Reply With Quote
I'm sure someone must know but i can't find it on the interweb .... what downlights can i fit in upvc soffit i guess they must be ip65 ... i don't want to melt the plastic soffit with hot lights ...... any ideas
rallyingden
posted on 28/10/09 at 09:36 PM Reply With Quote
Use LED versions.
Very cool running and low voltage so you can just chuck the wires olong the inside of the soffit.
RD
dave1888
posted on 28/10/09 at 09:48 PM Reply With Quote
^^what he says
big-vee-twin
posted on 28/10/09 at 10:36 PM Reply With Quote
Something like this would do the job
Linky
Sorry look at outdoor garden lighting on the above site see the IP68 LED fixture
[Edited on 28/10/09 by big-vee-twin]
http://www.triangleltd.com
woodster
posted on 29/10/09 at 10:09 AM Reply With Quote
thanks for help .... i'll just have to check that led give off enough light
omega 24 v6
posted on 29/10/09 at 12:30 PM Reply With Quote
You could use 2D fittings.
They give plenty light
Like these
MakeEverything
posted on 29/10/09 at 01:26 PM Reply With Quote
LED Lamps in a normal external 12V M250 fitting. You can buy ones specifically for LED, rather than buying the LED driver. They are cheap enough.
Try Wholesale Fittings (WF Electrical), in most industrial estates. OR RS components for a detailed spec.
Aurora make good quality gear, and if your using them in the soffit, then they wont get wet, so no need to go IP65.
Kindest Regards,
Richard.
