Author: Subject: fuel set up
kj
posted on 6/11/09 at 03:55 PM Reply With Quote
fuel set up
will a bike pump if mounted low down feed the carbs if the tank only has a out let on the top?
( the tank is a modified triumph spitfire unit)
It ran ok ok with the std pinto mech drive unit
[Edited on 6/11/09 by kj]
Think about it, think about it again and then do it.
locosaki
posted on 6/11/09 at 04:20 PM Reply With Quote
How does the fuel get from the top of the tank down to the fuel pump ?
Bike pumps like to push fuel around the system.
The outlet on the tank is usually at the bottom and that supplys fuel down to the pump and then pushed up to the carbs.
Hope this helps.
kj
posted on 6/11/09 at 04:32 PM Reply With Quote
the tank has an out let on the top which has a pipe into the bottom of the tank, it was just te see if the pump would pull up and then pump to the front of the car.
ashg
posted on 6/11/09 at 04:59 PM Reply With Quote
whats wrong with the pinto pump?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
kj
posted on 6/11/09 at 06:06 PM Reply With Quote
the std mech pump would over fuel the carbs
posted on 6/11/09 at 08:26 PM Reply With Quote
Bike pump won't see any difference once the system is primed.
