posted on 6/11/09 at 07:10 PM |
Water Pump... Mechanical or Electrical?
Can't use the OEM one on the RS4 engine, but there are spare drive pulley's I can use, or I can go electric... any one
'better' than the other?
It's Evolution Baby!
repper
posted on 6/11/09 at 08:33 PM |
ive looked in to that my self as a comon fault with the rover V8 that iam going to put in is that there run hot
iam thinking the electrical pump my be the way to go as rigged to some type off turbo timer it could be set to run on after the engine has been turned
off alowing water to keep going round the engine un till it had cooled down preventing any heat sincking your damge
austin man
posted on 7/11/09 at 10:00 AM |
if you fit an electrical pump couldn't it alsa be wired through the thermostat like radiator fans on newer cars. You often hear these running on
after stopping
posted on 7/11/09 at 10:14 AM |
Good point(s)... well made!
Cheers!
daKlone
posted on 7/11/09 at 10:53 AM |
I'd have thought an electric pump is less efficient than a mechanical one (mechanical -> electrical -> mechanical vs mechanical ->
mechanical).
Also you'd need to think about failure modes - what happens if the pump fails? If the battery is low etc. Also think carefully about anything
that runs on after the engine is switched off, as not only can it drain the battery there is also safety to take into account.
Sounds like a cool idea though!
dK
Winter is coming...
40inches
posted on 7/11/09 at 11:20 AM |
Lots of forum chat about leccy pumps HERE. The IMOC one is interesting, seems that mounting
position and angle is critical
posted on 7/11/09 at 01:23 PM |
mechanical).
all good point but bear in mind an electrical pump with controller would run as needed as opposed to be running all the time so may use up less
power.
regarding failure, you would need so means of monitoring the motor as well as temperature and have some indicator or engine cut off device.
ping Razman - he had one fitted and I think had good experiences with it.
