Author: Subject: Lightweight Alloy Pulleys
jeffw
posted on 11/11/09 at 07:33 PM Reply With Quote
I'm looking at a set of lightweight alloy pulleys for my Zetec (anodised red ) and wondered if anyone had any thoughts on if they are worth the effort or not.
The engine is 2lt in 45mm Jenveys with 285 Pipercams & vernier cam pulleys
Do we think that crank / waterpump and idle pulleys would make any difference ? Car already has a lightweight alloy alternator pulley
posted on 11/11/09 at 07:38 PM Reply With Quote
Lightweight crank pulley may make a difference to engine performance..
You say it has vernier pulleys, are they not ali and already lightweight???
jeffw
posted on 11/11/09 at 07:44 PM Reply With Quote
Yeap...already got Vernier Pulleys. Interested in the Crank Pulley aiding performance...
Mal
The standard crank pulley on a silvertop is of a two piece metal construction with a bonded rubber middle to the sandwich. This may serve a crank vibration damping function. if it does, it is not a good idea to remove it.
Mal
goodall
posted on 11/11/09 at 08:19 PM Reply With Quote
As said most modern engines use a torsional damper design, which if done away with you risk snapping the front the crank off. However they arent that effective and can be done away with, for most older cars didnt have them and considering the limited mileage of a kit I wouldn't worry. Also alot of tunned turbo engines, which produce alot of torque (ie twist the crank more) do away with the damper and dont fail
Im currently designing my own pulley and had have looked at these issues
goodall
posted on 11/11/09 at 08:50 PM Reply With Quote
Also, what is they say for every pound of the crank you effectivly get 1bhp. Don't know how much truth is in that how ever
Bluemoon
posted on 11/11/09 at 09:28 PM Reply With Quote
Not true, it increases the rotating mass but the static power (at a fixed RPM) will be the same.. I might increase acceleration mind as you don't have to spin up the mass but I would think this is negligible (it's a lot smaller than the flywheel, with a lot less rotating inertia)..
As to the mass damping function of the crank pulley I'd not change it unless you knew it didn't need it. The resonances that it's stopping are dynamic you might get awaywith it for a while but under certain conditions (load RPM, time held at RPM, missfireing ect) the vibrations build up in the crank and snap/crack the crank.
Model T had that issue as they had yet to work it out what to do (and hence limited to about 1600rpm!)..
Dan
[Edited on 11/11/09 by Bluemoon]
clairetoo
posted on 11/11/09 at 09:33 PM Reply With Quote
I read somewhere that 1kg off the rotating mass is the same as 10gk's off the weight of the car as far as acceleration goes - I have ally pullies and flywheel (something like 10kgs of rotating mass removed....) and it sure does pick up well
Its cuz I is blond , innit
Claire xx
Will weld for food......
Bluemoon
posted on 11/11/09 at 09:37 PM Reply With Quote
But if the pulley weighs 1kg or so that's not a lot, and you are increasing the risk of unreliability.. You would be better off getting a lightened flywheel, that will make a bigger difference ..
Dan
Danozeman
posted on 12/11/09 at 07:40 AM Reply With Quote
Are they the underdrive things?
I fitted a set of these to my mates st170 it made no noticable differenence but i think he said it should give 2hp more or something.
Dan
dhutch
posted on 12/11/09 at 11:01 AM Reply With Quote
Ofcauase with the, it depends where the weights removed.
- Its along the centerline of the crank with will make basicaly no diffrence to the car other then the actual added weight. If its right round the edge of the flywheel however, obvisouly it will add significat intertia to the flywheel which will mean it spins up slower and spins down slower, or is otherwise generally more flywheel like in behavoiour!
Again as said, reducing the weight of anything wont increase the horsepower. But i decreases the intertia/weight of it so will (to a greater or lesser extent) improve accelatation.
Daniel
jeffw
posted on 12/11/09 at 11:07 AM Reply With Quote
Certainly a reduction in rotational mass should improve engine response which, in turn, will aid acceleration. I would be very surprised if there was a increase in actual power output.
Lightweight flywheel is already on the list and the pulleys anodised red would be very bling
fatbaldbloke
posted on 12/11/09 at 01:13 PM Reply With Quote
Acknowledging I'm more-or-less admitting I should get out more...not so, Sir. The TR2 first produced in 1953, and most subsequent 4 cylinder TR's, had torsional damper type crank pulleys. These had a long nose which took a 4 bladed fan plus a socket to take the starting handle which was inserted through a hole in the radiator. Many owners fitted Kenlowe fans to take away the power consumption of the fixed fan and at the same time removed the long pulley (so the fan could fit). And lo and behold, crank breakages started to appear, usually at the clutch end which is where the undamped vibration was at its worse.
[Edited on 12/11/09 by fatbaldbloke]
snapper
posted on 13/11/09 at 08:25 PM Reply With Quote
If you did remove the Ford designed damper you would need to balance pistons and rods to get them even then rotationaly balance the crank, flywheel, clutch cover and front pulley of your choice.
I eat to survive
I drink to forget
