Author: Subject: Hayabusa drysump....oil hose dim?
Triggerhappy
posted on 19/11/09 at 02:24 PM Reply With Quote
I have an NOVA drysump system with JIC/AN-10 size hoses everywhere..
So 3,5feet -10 hose from scavange pump to oilcooler and then 3feet -10 hose to my Pace oiltank...
Is this not going to work well??
2008 busa engine!
Im from Sweden, so im escused...The Muppet drummer for president!!
Phil.J
posted on 19/11/09 at 03:13 PM Reply With Quote
It should work fine. I usually like a minimum of -12 on the scavenge side to be on the safe side, but have often seen -10 installed with no problems.
iiyama
posted on 25/11/09 at 11:55 AM Reply With Quote
-12 supply from the tank and -10 everywhere else for me......
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Jason Fletcher
posted on 2/12/09 at 09:38 PM Reply With Quote
I had 2ft of -10 from the scavinger pump to a Laminova then 6 inch of -10 to the tank then 4 inch of -12 from tank to sump. All worked well. If I were you I would get -12 pipe and fittings from the tank to dry sump but I am only saying that because it worked for me and if you speak to steve @ SBD he will tell you to use -16! Andy @ A.B has the -12 fittings for the sump.
jason
