Author: Subject: i've had it! engine mounts
t.j.
posted on 21/11/09 at 07:32 PM Reply With Quote
I was trying to keep the sierra mount and rubbers.
It is not a good idea......My exhaust and steering-shaft where causing troubles..
After hours of thinking i took the grinder and cut them out!...
So which mounts are small and capable to handle the 2.0 litre engine?
pfffffff. i'm cooling now
Steve Hignett
posted on 21/11/09 at 07:38 PM Reply With Quote
It's been a long time since I've done that in someones car, but isn't the preferred option LandRover mounts?
Hammerhead
posted on 21/11/09 at 07:44 PM Reply With Quote
jag e-type/caterham ones?
Canada EH!
posted on 21/11/09 at 07:55 PM Reply With Quote
Old round puck Volvo, Volvo 122, looks like a hockey puck with a threaded bolt out of the top and bottom, sides can be trimmed to fit, they kept a 2 L volvo torque monster in check. i used them on my race car and Twin Cam toyota 4AGE. powered Locost
indykid
posted on 21/11/09 at 08:01 PM Reply With Quote
i think i still have these. they're from MK but i think the angles of the plates might be a touch off. i ended up remaking some for mine but if i still have them, you can have them for a tenner. you'd just need some fiesta gearbox? mounts or landrover engine mounts i think the other one is.
tom
Daddylonglegs
posted on 21/11/09 at 08:17 PM Reply With Quote
Here's mine:
I used LR rubber mounts too.
JB
[Edited on 21/11/09 by Daddylonglegs]
speedyxjs
posted on 21/11/09 at 08:27 PM Reply With Quote
Heres mine. I used jag/landrover ones (well i would wouldn't i ). Mount is made from 4mm steel scraps i had lying around.
N/S Gearbox Mount
N/S Gearbox Mount
[Edited on 21-11-09 by speedyxjs]
t.j.
posted on 21/11/09 at 08:57 PM Reply With Quote
Those Landrover mounts look tiny.
Are they the gear-box mounts?
Anyone the numbers, so I can order them?
norfolkluego
posted on 21/11/09 at 09:17 PM Reply With Quote
Try these, £7.37 from Westfield
http://www.westfield-sportscars.co.uk/shop/product.asp?P_ID=243&strPageHistory=search&strKeywords=mount&numPageStartPosition=1&strSear chCriteria=any&PT_ID=all
[Edited on 21/11/09 by norfolkluego]
l0rd
posted on 21/11/09 at 10:01 PM Reply With Quote
I have 2 for sale if you are interested
johnston
posted on 21/11/09 at 10:07 PM Reply With Quote
I've always thought the cut down ford TCA's always made tidy mounts.
posted on 21/11/09 at 10:34 PM Reply With Quote
I've also got two of those knocking around my garage somewhere... Quite heavy though...
Angel Acevedo
posted on 22/11/09 at 07:09 AM Reply With Quote
I am using a 5.0 V8 and was thinking to fabricate my mounts with Hat bushings like the ones used on a-arms (Wishbones).
There´s a link somewhere in a 4 X 4 forum.
HTH
maartenromijn
posted on 22/11/09 at 07:18 AM Reply With Quote
I have these Landrover engine mounts. Cost approx € 10,- per 2, delivered to Holland!
BLOG: http://thunderroad-super7.blogspot.com/
Bluemoon
posted on 22/11/09 at 09:40 AM Reply With Quote
I used the sierra mounts, fabricated mounts from 6mm plate in the end (over engineered, but the plate was free!), this makes clearance a lot simpler to achieve.. The original sierra rubbers are good, the engine does not seem to move about that much at all, like you have found they are taller than the other solid rubber options.
Dan
